Results 1 to 3 of 3
Thread: Send and Recieve Commands to a COMM Port?
    Sep 2005
    Is it possible in RR to Send and Recieve Commands to a COM Port? I dont know if the sendkey command is something to do with this.
    Well, two reasons?
    1. I am looking at implementing a system were by I use my cars ODB interface to send an recieve command too and from the car. For example volume up button on the steering wheel would generate a command that could be picked up via odb and that command could then be given a rr equivilant command like "vol+". Equially it would be quite cool if you could send the command down the odb interface to wind up the windows or something from the computer.
    2. I have noticed that we (the rr community) are looking at creating a phone plugin for RR. I guess this will be done in much the same way as I have stated above. If this feature doesn't already exist it may be worth adding it so we can add our own phone commands from rr.
    Thanks for reading
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't know enough about OBD to even know if this is a crazy idea or not, but I was under the assumption that OBD data was ONLY to and from the car's engine control/monitoring unit and had nothing to do with audio controls whatsoever.
    It should be very easy to make a little application based on the SDK example to read from the serial port and issue commands to RR though..
    From my stand point, getting info to and from a phone is hardly anything like the above.. From all I've tested, most phones lack a standardized interface, regardless of them all supporting the same AT commands for GSM standards -- all phones I've played with had indeed the same commands but could not be used in the exact same manner -- making it incredibly time consuming to adapt code for each type of phone.. so all I say is: hat's off to Zorro -- I (myself) wouldn't touch that crap with a 14-foot stick.. but hey, anybody is welcome to try..
    Ride Runner RR's Myspace
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by guino
    Skinning to go... VisualDesigner2!
