Results 1 to 7 of 7
Thread: Road Runner wont exit after reformat?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Last weekend i did a reformat on my system. I backed up my rr folder, reinstalled it using the install wizard, updated.. then copy the back up rr folder to the new rr folder. Everything is working as should cept for the fact that when i hit exit to try to close rr it just freezes up until i kill it in task manager. What could be wrong?
    Live mp3Car Facebook Chat
    May 2005
    Vienna, VA
    Do you have any plugin like CDRIP? Check Exectbl.ini to see if you have a modified QUIT command.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've seen this happening for instance, when you DUPLICATE entries in exectbl, say like:
    "QUIT","xxxxxxxxxx||bye"
    "BYE","QUIT"
    "BYE","QUIT"
    In my case, I was trying chucks skin and it had the same entry in the skin's exectbl.ini as I had in the main one under RR's folder. Duplicates like above can easily cause the issue. If you turn debugmode on, it should log the command it's executing multiple times (the one you should look for).
    Ride Runner RR's Myspace
    Woodbridge, VA
    Blog Entries
    55
    didnt even dawn on me to check that file. i bet thats what the issue is. I'll check and letcha know
    Woodbridge, VA
    Blog Entries
    55
    nope that wasnt the problem. There's only one exit command and its this:
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    I tried using a different rr.exe. Same problem. Double checked rrconfig and its set correctly. Checked the skin. Checked by typing out "quit". What could it be
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I had exactly the same problem. It turned out to be that I had two instances of
    Exectbl.ini, one in the root RR dir and one in the skin dir. I erased the lines that were duplicate in both instances from the copy that was in my skin dir and the problem went away.
    The road is long but we are getting there.
    Woodbridge, VA
    Blog Entries
    55
    That was my problem hadda exectbl.ini in my skin folder. But i really dont know why. Oh well... problem solved
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  3. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 01:31 AM
  4. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 03:48 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
