Results 1 to 9 of 9
Thread: Flash issues on RR update?
    Newbie Xero's Avatar
    Apr 2006
    Northern VA
    Unhappy Flash issues on RR update?
    Well, this is definately nothing short of bizarre. After I copied the new RR release over to the car, all the flash movies in the skins lost their transparencies.
    For example, I personally use Simplistique, with the flash clock in the center. I've tried I think 3 or 4 different clocks, none of them show up properly. They all have a colored box around them instead of being transparent. As a result, I end up with the flash file overlapping my menu buttons. I think it's going to drive me mad if I don't fix it soon, any ideas would be helpful.
    I already reinstalled flash and the other OCX, and I searched for solutions, etc, etc. No luck for me, I guess.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Xero
    I had a similar problem on my desktop.....installed the latest Flash update but did not cure the problem. Went back to a 1/5/2006 RR executable for the cure.
    I think in my case this was caused by my using an EXE from Robby BMW to address Phoco issues. He does say in his thread that at the time he could not get hold of the latest EXE and used an earlier one for compiling his changes.
    Maybe this is whats happened with you too
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Apr 2006
    Northern VA
    Wtf!?
    Okay, now here's the kicker: it fixed itself.
    I had rebooted it before, nothing was working to fix the problem. I was sort of stupid this morning, and plugged in my iPod before the PC had a chance to finish resuming from hibernate, causing it to crash before it could fully restore. Somehow this caused flash to work right... uh... not quite sure how the two are even remotely related. Oh well, it works now. Thanks for trying!
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    I'm sorry. I've compiled the beta release with a wrong flash ocx.
    download the last beta here with the issue fixed.
    Apr 2006
    Northern VA
    Thanks for the update, I'm stuck with no PC for a day or two though... trying to fit the thing in my center console. I'll try it as soon as I get up and running again.
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Interesting, I have just bought a new laptop, and copied the files over from my old laptop where everything worked. I am now getting a loss of transparency for my flash gauges !
    The new rr.exe from Robby (post 4) has sorted this out, but I don't use Phoco (yet) ! Will the changes made here make it back into the next release of RR ?
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it's really simple. WHENEVER it doesn't work, you SHOULD update the flash version and it SHOULD work.
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    guino, FWIW, I have the latest flash version. If I use Robby's version of RR posted in this thread (the one he said was compiled with a different flash.ocx), it works fine. However, if I use the latest RR version from the updater, flash transparency suddenly doesn't work. So for now, I'm using Robby's version.
    Maybe you should check back with him because there seems to be a difference between the 2 versions.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    thats really odd. i just compiled my own rr from guino's source and flash transparencies are still fine.
    Live mp3Car Facebook Chat
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. sending keystrokes to flash?
    By Nitrov8 in forum Road Runner
    Last Post: 04-07-2006, 01:51 AM
  3. Having Two Issues with RR
    By mnetwork in forum Road Runner
    Last Post: 02-25-2006, 02:13 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. Can RR set frame of flash movie?
    By Arathranar in forum Road Runner
    Last Post: 06-09-2005, 10:57 AM
