Results 1 to 10 of 11
Thread: Indicator not working with variables
    Raw Wave lostreception's Avatar
    NY
    Hey guino,
    "FILE;C:\MyInd.GIF" will work on my machine but "FILE;$Imagepath$" will not
    is this a limitation or am i overlooking something
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    indicators dont support variables.. didn't think there was going to be any use for that, but I could add it.. although, what's the difference of changing the variable $imagepath$ as opposed to changing/renaming the files around ?
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    guio, sometimes we want to change the file to be monitored in the indicator from an external app.
    This is kinda similar to how I want to use a $variable$ in the SD tag. If you would expand support for $variables$ in objects other than labels, that'd be great.
    While we're on this topic, I've noticed that if you have a button on top of an indicator, when you mouse over and out of the button, the indicator will be gone, too. Is this a limitation (since you probably have the "on" state of indicators and buttons on the same layer) or is it something you can fix?
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    NY
    Quote Originally Posted by guino
    my reason is more in keeping the code clean and simple for skins and gpsgas rather than using "full path to stationnumber1'simage file.bmp" i can just put "File;$STATION3_IMG$"
    thats the only way ive figured i can load images into the skin semi dynamically and change them besides making a new indicator via myextension.dll
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    guino's Avatar
    Nov 2004
    Toronto, Canada
    don't worry, I was already planning to add it.. b8bboi, I've already added support for definitions with variables, I think I posted you a link to the test version, not sure you saw it.
    May 2005
    Vienna, VA
    I'm not sure where you posted it. Is that the one from this link?
    http://www.rrdownloads.net/beta/rr.exe
    I'll give it a try.
    May 2005
    Vienna, VA
    guino, just tried it. The variables don't seem to get updated in this version (all of them, not just the ones used for indicators).
    I roll back and they work again (but of course I don't get the file indicators).
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I only added the variable support for definitions on that version.. I haven't messed with indicators yet.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that test was only for the variables on .skin definitions.. I haven't messed with indicators yet.
    May 2005
    Vienna, VA
    actually, it did work for my file indictor.
    What I meant was that when you update those variables from outside using SETVAR, they don't change.
  1. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 03:24 AM
  2. EPIA M10000 TV-out not working!!
    By JayKaye in forum General Hardware Discussion
    Last Post: 02-08-2005, 02:41 PM
  3. TS working... not working... work... not...
    By bulgogi777 in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:25 AM
  4. All built and working, just one last problem......
    By Matthew230 in forum Power Supplies
    Last Post: 10-18-2004, 04:02 PM
  5. Got GPS 16 working
    By tekknikal in forum General Hardware Discussion
    Last Post: 06-16-2002, 06:55 PM
