Results 1 to 6 of 6
Thread: WMA files
    Jun 2006
    WMA files
    Hi
    i have a music folder mixed with mp3 and wma files. i do not understand, why the wma files are not playing in rr. with winamp alone it works fine. if i start rr then after, i can still hear the wma files. but if i play them directly in rr it doesnt work (stop). any ideas?
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Have you tried to add .wma files in rrconfig ?
    check your rr.ini file. I have my audio and video set like this
    videofiles=.AVI,.MPG,.MPEG,.RM,.RAM,.VOB,.ASF,.WMV
    audiofiles=.M3U,.MP3,.WMA,.OGG,.AAC,.MPC,.VQF,.CDA
    if .wma is not on your entry, that will be the problem.
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    also, when you add a file type to rr.ini make sure you add "all" the file types you want to play, once you add one file type it will only play whats listed after that. Its also case sensitive so if you have MP4 and mp4 files you have to add both or rename the files.
    beer replenishment fund
    mp3car live search
    Dec 2003
    West Midlands
    Now theres something I didn't know.
    Case sensitive huh, I need to redo my entry !
    cheers LS
    KPJUK
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I thought if you left the audio format list blank it played all supported formats??? Thats how mine is.
    I've never come across the case sensitive thing either,mine work fine as MP4 or Mp4 or mp4.
    In fact you've probably enabled the format thing by having any kind of entry there,its probably expecting you to specify all formats now.
    Aug 2003
    Chicago
    Quote Originally Posted by Griff1
    well thats what i was basicly saying, by typeing anything in the format section, it automaticly will from then on only read those specified formats instead of the default formats plus what you specify.
    If you leave it blank it will play all "supported" formats, but some formats are not in that list, like MP4 files or ACC files, but they still work if you manually add them.
    i may have the case sensitive thing mixed up, (didnt test to make sure) but i think i got confused cause i added MP4 and M4A and thinking in my mind that they are the same file types
    mp3car live search
  1. Access 2003 help needed
    By veedubya in forum Off Topic
    Last Post: 05-31-2006, 07:49 PM
  2. I Have Voices!
    By Andywaite in forum FreeDrive
    Last Post: 01-18-2006, 06:07 AM
  3. WMA files not selectable/viewable in FP
    By spinedoc in forum FrodoPlayer
    Last Post: 09-06-2005, 01:11 PM
  4. WMA Tags?
    By phoenix96 in forum FrodoPlayer
    Last Post: 07-19-2004, 10:06 PM
  5. Has anyone gotten ME v2.0 to play WMA files yet?
    By bertybassett in forum ME Archive
    Last Post: 10-26-2003, 06:30 AM
