Results 1 to 7 of 7
Thread: RR freezes after 5 minutes
    Mar 2004
    New Jersey
    I have been running RR for a few months now and all of the sudden it will lock up after 5 minutes of use. Dosent matter if its XM or Mp3. I loose total control of RR. I have to End the task and try again.. I havent changed anything hardware wise. Winamp still plays, XM still plays but i have no control over RR. This just started happening yesterday. I am running the april version of RR. Running Winamp 2.92
    Is there a log file or anything i can look at?
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    Apr 2006
    do you have a vibrate kit for your hard drive? if not check it your hard drive problably receive enough shock to cause RR freezing, give a PC a break and try to put it somewhere tight, happened to me last week. noting to do
    Mar 2004
    New Jersey
    I am running in a laptop in the trunk. Its mounted in the trunk.. i have never had a problem with bumps before.. I tried that theory standing still in my driveway and it still froze. good idea tho.
    -Jack
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can add debugmode=true to RR.INI and it will make a debug.txt log file. I'll be honest to say that if it freezes after a few minutes of use (without you changing any settings), it sounds more like some sort of hardware issue. Please check your CPU load also. In any case, I think you should make a backup of your files and install the latest version to see if the problem goes away. You have no idea of just how much difference there's inside RR from release to release every month, so you should at least try the new version.
    Another thing you can do is, start disabling features, say, XM & GPS Port, etc.. see if it doesn't freeze anymore, if you can relate the issue to something specific it would be very helpful fixing a possible problem.
    Ride Runner RR's Myspace
    Mar 2004
    New Jersey
    Quote Originally Posted by guino
    Thanks for the support. This weekend i was going to reinstall anyway. Also i might as well do the upgrade and also get winamp 2.95.
    Is there any disadvantage to leaving debugmode=true all the time?
    I would like the ability of constant monitoring.
    -Jack
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    It will slow RR a bit and if you are constantly changing screens/pressing buttons the debug.txt will grow pretty large.
    Beer is proof that God loves us and wants us to be happy Benjamin Franklin
    Mar 2004
    New Jersey
    Quote Originally Posted by DiNASTY
    Would you look at that... it was a bad 5v power source to my usb hub.. replaced and all is good..
    -Jack
  1. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
