Results 1 to 7 of 7
Thread: Sound problems after install
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Exclamation Sound problems after install
    Hi.
    I installed RR on ym laptop to try it out before i consider it for my carpc.
    the problem is that after i installed and used RR, now music on my pc is different.
    I get a sort of echo!!! :@
    I think it might be its RR's equalizer or summin, but i put at a normal level.
    How can i get my "original" sound of my music back.
    Any suggestions?
    MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    On your laptop, is your mic turned on???
    What version of Winamp and check your settings for it.
    Recheck your windows settings for audio devices.
    Finally, check the audio settings for master volume control under RR.ini config file.
    Aug 2005
    Gibraltar(UK)
    I've checked all those settings axcept for the ones in the RR .INI file.
    What should i look out for?
    Oct 2005
    Arkansas
    Quote Originally Posted by ironic
    Map master volume entry.
    If you checked your windows sound settings for playback of MP3 and your sure that you don't have some enhanced sound setting for 3D or widening as some laptop sound devices have this option and you don't have Phoco or similar program that is turning on the Mic, then maybe someone will come along and lead you to a better place.
    It seems to me that Chuck had a problem a while back on echo or similar weak sound issue and his turned out to be a hardware issue on the amps.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    make sure you dont have a dsp plugin switched on in winamp
    May 2005
    Vienna, VA
    Yeah, open Winamp alone and turn off all EQ settings and remove all DSP plugins.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Aug 2005
    Gibraltar(UK)
    done that.
    Still same problem...:@
  1. iguidance install problems...
    By shrinkydinx in forum GPS
    Last Post: 02-04-2007, 02:28 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  4. sound output problems laptop;winamp;iguidance help!
    By mpfjr in forum General Hardware Discussion
    Last Post: 09-01-2004, 09:23 PM
  5. Sound problems with MPXPALY
    By mad man in forum General Hardware Discussion
    Last Post: 10-24-2003, 06:38 PM
