Results 1 to 2 of 2
Thread: RR send key question
    Oct 2005
    Raleigh, NC
    Hi all,
    I'm still getting familiar with RR and am now trying to set up a custom RR command to send a hotkey to MM. As a test, I set up the ini files as follows and renamed the close button on the destinator skin to "COMMAND1"
    MM hotkey.ini = letters S,M for the switch map command. This works fine with keyboard strokes.
    RR KeyTBL.ini = 37,"COMMAND1"
    I also tried with the DESTINATOR_GPS suffix on the end, spaces between the - , comma between S and M etc and got either nothing or the voice prompt saying "command1"
    What is wrong with my syntax? BTW I am loving this program!!
    Thank you,
    May 2005
    Vienna, VA
    For Map Monkey, you should use the "MM_" commands. Read Skin Commands.txt for more details. Then read MM's SDK documentation for available commands.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 06:05 AM
  3. RR 03-06-05 - Radio Preview ...
    Last Post: 07-04-2005, 02:58 PM
  4. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
  5. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
