Results 11 to 20 of 24
Thread: 1 for Guino.
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ALL lists in RR are transparent and ALL ignore the backcolor parameter.
    Ride Runner RR's Myspace
  2. #12
    Constant Bitrate Sweet05's Avatar
    Apr 2006
    I fully understand the question and the anwser is yes. Here is a picture of it in action:
    To Download this skin and assist in it's making go here.... The Skin Skin
    Here is the code used for the play list. According to guino you can do the same thing with PB lists also.
    Code:
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S,296,112,502,286,0,64,128,0,255,255,0,0,0,0,64,128,0,255,255,TRUE,22,"ChickenScratch AOE"
  3. #13
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by guino
    The Phone list CAN be transparent just like the playlist. There's a limitation of the Text entry field not being transparent -- it's way too much code to make it transparent.
    Guino,Would it would be any easier to code for a background image for text entry box's (instead of,or in addition to the RGB color?? so i could just specify an image.
    Then i could copy the image area the text box covers and achieve a transparent effect.
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The problem is that TEXT field inputs in Windows GDI are very limited and do not offer transparency. I'd need a ton of UNSTABLE code just to make it transparent. The only way to make it transparent would be to make it a LABEL, which means you'd loose the ability to type directly to it with a keyboard AND you would not have a cursor AND you'd not be able to copy/paste to/from it.
  5. #15
    May 2005
    Vienna, VA
    yup, Windows text field inputs don't support transparency nor background images.
    PITA for me when writting apps, too. Sometimes I have to simulate it by having the user type in another textbox and updating the content on a label.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by b8bboi
    Sounds like a plan.
    how about having a look at the RR source and see if you can adapt it in that way
  7. #17
    May 2005
    Vienna, VA
    I don't think that'd be a good idea. You won't be able to set the focus on the text field by clicking on it nor cut/paste like guino mentioned.
  8. #18
    Nov 2005
    Midlands
    This sounds interesting,how would i do this in rr?
  9. #19
    May 2005
    Vienna, VA
    sorry, you can't. I was talking about writing a VB ap.
  10. #20
    Nov 2005
    Midlands
    I only want the option in the phoco section and have no use for cut/paste or other function.
