Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: WinTV USB FM Problems
    Low Bitrate BioHazard's Avatar
    May 2006
    Luxembourg, EU
    I use WinTV USB FM Tuner and Roadrunner, everything works fine, but :
    1) When I start Radio in RR, he starts the last frequency listened to and removes the numbers after the period, example : last freq: 99.90 , after restart of app: 99.00
    2) I can add, modify, delete presets, but I can't use them. When I select a preset (in RR) it just makes a "dong" sound (windows default) and no freq is changed. . .
    Project BioHazardous Material || BioHazard . LU
    ████████████████░░░░ CAR
    ████████████░░░░░░░░ LAPTOP
    █████████████░░░░░░░ FRONT-END SKIN
    ██████████████░░░░░░ PERIPHERALS
    ░░░░░░░░░░░░░░░░░░░░ INTEGRATION
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try changing your regional settings, or downloading a different version of the wintv radio application. This is happening because RR is sending a . or , when the wintv radio is expecting the other one. In most cases this should work itself out normally.
    Ride Runner RR's Myspace
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Your presets aren't working cos your using the old version of the wintv app or driver,!UPDATE!
    May 2006
    Luxembourg, EU
    I've downloaded a newer version of WINTV but it asks for the CD Version of the NUVision.sys. Installed the newer version.
    Started TV in RR: Restarted my PC.
    Started TV plugin in Winamp to check if there are configs to modify: Bluescreen "NUVision.sys" Memory error.
    I'll try that tomorrow, I'm to sleepy now. Good night
    May 2006
    Luxembourg, EU
    Good morning.
    I changed the regional settings from , to . .
    Now, when I start the radio in RR, the preset is loaded into WinTVRadio, with the correct numbers after the period. But when I select another preset, I hear a short pause, the RADIONUMBER and RADIONAME tags change, but the frequency doesn't change.
    EDIT: That problem is coming up in ALL Roadrunner skins I've used. Also note that the "TUNE" function doesn't work.
    I'll try to make the TV working now.
    EDIT: The TV works now, I have re-de-installed and installed the drivers, seems that I had missed something yesterday.
    EDIT: Strange: I test my RR and peripherals on my main PC before copying it to my laptop. So I don't run RR full screen, and have other apps working. When I have TV running in RR, and I click on an app in the windows taskbar or I change apps in ALT-Tab, TV changes to channel60 everytime, it doesn't do that in Winamp, just in RR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-If you've changed regional settings, delete radio.ini
    2-open the wintv radio application and type in frequencies like: 92.50 and 92,50 and see which works (with , or . ).. run RR and check that radio.ini is using , or . according to your regional settings.
    May 2006
    Luxembourg, EU
    WinTV Radio is using . before and after regional settings change. But RR is using , before and after change.
    The radio.ini look the same after I delete them and change the settings:
    Code:
     9320
    10110,Pure FM
    10220,Radio Contact
    9320,Classic 21
    Any chance it will work if I download WinTV Radio from the US Hauppauge site?
    EDIT: The only thing that changes after a regional settings change is the frequencies show in the radio preset list in RR. no change in radio.ini
    EDIT: Doesn't work with US version too. . .
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yeah, I forgot I made the ini work the same way regardless of regional settings, but if your wintv radio is working with ( . ) RR should be set to work with the same.. you can find out how RR is working by pressing the tune button and then hitting the "." button in the Numeric OSK.. it should place a ( . ) or a ( , ) according to your regional settings, which hopefully should be what the wintv radio works with.
    May 2006
    Luxembourg, EU
    Ok, I tried out the OSK, and it did put a (.) or (,) according to regional settings change.
    radio.ini puts a (,) regardless of regional settings. . . .
    WinTV however does only work with (.)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that's weird. The WinTV radio >should< work with your regional settings as well.
    However, as long as your regional settings in RR match with the ( . ) in the WinTV radio application, it should work fine. If you've tried that and it doesn't work, post the version and a screenshot of your wintv radio application.
  1. Problems with Holux 213 USB
    By Toad in forum GPS
    Last Post: 07-13-2007, 07:45 AM
  2. WinTV USB with FM
    By VitalRyan in forum General Hardware Discussion
    Last Post: 05-13-2006, 08:17 PM
  3. wintv usb fm
    By corsab in forum Road Runner
    Last Post: 09-29-2005, 01:20 PM
  4. USB FM Radio with RDS/RBDS
    By skippy76 in forum General Hardware Discussion
    Last Post: 11-22-2004, 05:16 PM
  5. USB FM modulator.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 10-01-2004, 02:24 AM
