Results 1 to 10 of 14
Thread: help for one fed up mancunian
    Jun 2006
    HEEEEEEEEEELLLLLLLLPPPPPP
    i cant get music to play through rr when i click on music buttons. i set config to correct path for music on my hard drive, it find files but then wont play them (through winamp) am i doing something wrong - ive searched through forums all afternoon with no luck.
    what ive done/can do - reinstalled winamp into same folder as rr (would that matter so long as path is correct?)
    i can play music through winamp but not through rr
    do i need to load playlists etc into winamp - i tried but still no luck
    any advice for a noobie much appreciated - i can type and i can follow instructions, just sometimes not at the same time. i cannot knit and dont like hoovering up!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    winamp doesnt have to be in rrs folder you should leave it in program files as thats how its default in the config. Load a playlist into winamp, close winamp, then run rr. can you play ?
    Live mp3Car Facebook Chat
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what version of winamp are you using. Although the recommended version is 2.9 ive had success with newer versions up to 5.1, anything after 5.1 seems to bring a bunch of issues with just winamp itself and even more if used with RR.
    Is it a clean winamp install, may be a plugin acting weird. Generaly though, if you can hear music in winamp, RR shouldnt have any problems.
    beer replenishment fund
    mp3car live search
    Jun 2006
    thanks gents - i can play winamp as a standalone - when i stop winamp and launch rr itd when i get problems - im using lite version from downloads page,
    the pause button keeps flashing when i click on music but nothing happens?
    does this mean its reading the whole drive? any ideas as to why it should flash?
    i think a new install of rr is on the cards soon, just in case?
    dave bev
    Aug 2003
    Chicago
    i dont know about the lite version of winamp, i know some things are missing. Maybe try the fullversion.
    the pause button flashing (which skin) is prob just an idicator that your music is paused or muted.
    are you running the latest version of RR, not that it would matter, but always best to have latest fixes etc.
    mp3car live search
    Jun 2006
    went for a full reinstall of everything - five hours of forwards on step, backwards two! finally sorted, your posts helped because i could see there was no real reason it shouldnt work, so it had to be a software issue (methinks!!)
    again, thanks for your help
    dave bev
    Aug 2003
    Chicago
    when you say everything you dont mean windows do you? Just RR and winamp. Either way, its working now so go take a drive and listen to some tunes
    mp3car live search
    Jun 2006
    if only i could - i havent got to that stage yet, im still experimenting with the set up at home to make sure i dont have those problems on the road. not even installed in the car yet though i have the basics of a system, just putting one together as an experiment rather than spend a load of dosh on something i dont use
    dave bev
    Raw Wave
    Jun 2004
    On the beach
    It will have been the lite version of Winamp, I'm sure I remember in the FAQs that the lite version doesn't work with RR.
    Wish I'd seen this thread earlier, could have saved you quite some time.
    Jun 2006
    actually the lite version is the one i have working? i uninstalled everything, then installed the lite version, then installed rr and subsequent web updates and everything seems ok so far!
  1. Accidently Fed TOSlink Converter a 12v rail
    By c0rrupti0n in forum Car Audio
    Last Post: 12-27-2005, 10:29 PM
  2. Fed Up!
    By sq_geek in forum General Hardware Discussion
    Last Post: 07-12-2005, 02:00 PM
  3. ARGHHH now i am getting angry and fed up!
    By Scouse Monkey in forum Off Topic
    Last Post: 01-07-2005, 09:21 PM
  4. Taskbar all F'ed up .... XP related
    By Don 944 LA in forum Software & Software Development
    Last Post: 12-02-2004, 12:22 PM
  5. Fed up with Pundit
    By craigyb in forum General Hardware Discussion
    Last Post: 06-21-2004, 05:40 PM
