Results 1 to 9 of 9
Thread: Winamp randomly hangs
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    hey, i HAD a good working system, until i reloaded windows(drivers curupted something bad)
    anyway,
    with my fresh install using the latest version of RR, and winamp v2.8, winamp or road runner randomly hang.
    i think the problem is with winamp, i've also tried winamp v5.02.
    any ideas?
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Normally this is either a bad plugin or bad hardware, RR+Winamp are normally VERY stable alone. Also, 2.8 is NOT a supported version (2.9+ are).
    Some people complain of 2.95 freezing right at startup, and the only time I've seen that happen was when my Media Library had corrupt data in it.. once the Library was deleted it started to work fine again.
    Ride Runner RR's Myspace
    May 2005
    Elizabeth City, NC
    where can i find inamp 2.95 or will 5+ work, i thought i saw something about problems with that? will do some searching...
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by guino
    Its funny you say this I've suddnely developed the same prob with the recent RR version - the whole PC stops.... then a few mins later carries on as though nothing had happerned ( Thought it was my Bluetooth at first still testing that ) ... Was not going to mention but having seen this post thought I may as well.
    Just to check 'Media Libray' I'm not using any m3u files at all... is this what you mean G ?
    Cheers
    Terran
    EDIT - Not sure if this helps but enabled don't reload play list around about the same time... will have a play tommrrow see what happerns.
    May 2005
    Elizabeth City, NC
    as a note i rolled back to an earlier version of RR that i had on my archives dvd, and the problem went away. (April Release i think it was)
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Media Library is a plugin that comes standard with winamp. It normally comes disabled, but if you even just play with settings it will start running... you can simply open the ml folder in winamp and delete the .dat files if you suspect of it.
    May 2005
    Elizabeth City, NC
    i found the problem(i think)
    one of my usb wires coming from the touchscreen(goes to a hub with my soundblaster) had the insulation rub off, and one wire exposed, if i hit a bump it would short to ground !!!! i've replaced the cable, and moved it and secured it(gromets and zip ties) .... will keep you all posted if this did not fix for me(note still using earlier version)
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    Jan 2003
    I'm still working on mine - changed the setting last night made no diffrence now just working back on the changes I made recently to rule them out.
    Terran
  1. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
  2. Finally broke winamp 2.95
    By blk02si in forum Road Runner
    Last Post: 04-28-2006, 10:40 AM
  3. Winamp volume problems
    By froop in forum Road Runner
    Last Post: 09-17-2005, 12:02 PM
  4. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 01:07 AM
  5. Winamp install gets corrupted randomly...
    By Chita79 in forum Road Runner
    Last Post: 06-02-2005, 07:41 PM
