Results 1 to 10 of 15
Thread: Sorting Music to go by Track Number
    Low Bitrate SuprchargdMazda's Avatar
    Mar 2006
    Music lists get loaded alphabetically but I want it to go by track number? Why does it do this. Am I going to have to open every single music folder I have and change the "Arrange Icons By" to Track Number??
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    No, you'd have to either make playlists in the order you want, OR rename the files to where they have a format starting by track number. There are many tools that can do both.
    Ride Runner RR's Myspace
    May 2006
    Calgary, Alberta
    Write a java program, it'll do it in a second.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Quote Originally Posted by guino
    Care to name one I can go find and download off of a torrent or at least a trial version?
    May 2006
    Calgary, Alberta
    There must be a hundred on www.download.com. If I had a code editor on my machine, I'd write one for you in 10 minutes.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    I tried out two of the more popular ones and my cousin sent me one program too, but all of them I end up needing to click each folder then going to like Edit-Track Listing Sorting whatever so its the same thing as just manually doing it because I can't select just My Music and having it sort everything in there. Could you name what program you're using?
    May 2006
    Calgary, Alberta
    Sorry man, I went through all 2000 songs and renamed them individually. Took me 3 days or so.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    I don't suppose you realize you can arrange them by track number in Winamp and then close it. And when you open Road Runner, it'll pull that same order into it. I always load the list into Winamp the way I want and do it that way.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Constant Bitrate Sweet05's Avatar
    Apr 2006
    I use WMP to orginize my entire collection if you have everything in folders properly (i.e. Music>Artist>Album) just drag and drop the whole music folder into WMP. WMP will look for any tags that are not present and update your file tags too. Once everything is in WMP and tagged correctly (with very unorginized music collections you may want to drag and drop one artist at a time into the library to make it a bit easier to tag it all) select "Tools>Options" on the "Rip Music" tab select "Change File Name" and set the files how you like with the track first in your case. Then go to the "Library" tab and select the check box "Rename music files using rip music settings". Now it "OK."
    It takes WMP a while to rename all the files but you can speed up the process by going to the albums catagory in the library browser and right click each album and select update album info. WMP saves the album art as hidden system files also and currently these can't be seen inside RR but I have fixed this and supplied guino with the code so hopefully it will appear in the next release. I like the way WMP automates alot of things like getting tags automatically and album art and renaming the files just the way I want them.
    One word of caution if your music has no tags but all the info is in the songs file name don't select the rename files option til all your tags are right or you will end up with a bunch of files named "00_Title_Artist.mp3"
    May 2006
    Calgary, Alberta
    Where does this thing get the information for the file tags? None of my songs have tags but I'd be interested in a program that would input all of that for them. I just don't see how it could pull the information from the air.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. mp3 names in Mediacar to include track nr?
    By fly_dutchie in forum MediaCar
    Last Post: 07-15-2004, 01:53 AM
  2. GPS / Music Volume Issues
    By shakes in forum MediaCar
    Last Post: 07-08-2004, 04:47 PM
  3. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  4. Error #91
    By SiGmA_X in forum ME Archive
    Last Post: 01-08-2004, 10:40 PM
  5. Replies: 9
    Last Post: 09-29-2003, 02:21 PM
