Results 1 to 6 of 6
Thread: Mute on GPS Direction?
    Nov 2004
    UK
    I'm in the early stages of planning a system.
    I want to keep the existing head unit - I spend 90% of the time listening to the radio and about 10% to CDs.
    My primary use for a car PC is for GPS navigation, but I'd also like to be able to connect my ipod and play tunes directly off the HD, and use phone integration. My intended choice of software in Roadrunner and iGuidance.
    I definately do not want to watch TV or DVDs, or sat radio.
    My intention is to connect the head unit output into the line-in of the sound card, and then the line out to an amp, and then back to the original speakers. This way I can keep the orginal head unit working.
    My question is what happens when the GPS software gives directions - I've seen that RR has the factilty to drop the volume, but will this do both the line in volume, and the winamp volume if I've got the ipod going.
    Also, is it possible to have RR auto mute the line-in if I've got win amp playing?
    Cheers - as you can see, I've got a lot to learn!
    Ian
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Yeah, keep learning... (start with the search button ***search tip: IGmon***)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    If you ask me, you'd be better off getting an AUX-In adapter for your HU and plugging your CarPC into that. Then you can keep the volume control on your HU too.
    Nov 2004
    UK
    Quote Originally Posted by RPM_VR4
    The reason I hadn't planned to do this is because I'll be mainly listening to the radio, so there will be no way for the Car PC to interupt the music with nav instructions or phone.
    Thanks for the iGMon tip
    Ian
    Nov 2004
    UK
    I've been reading some more. I've now discovered the Phidget board and relay control.
    I can use a relay to switch the head unit to mute when playing from the iPod (I presume I can add a command to the switch to audio screen to also close the relay, and vv).
    Can iGMon also trigger the Phidget relay if it has something to say?
    Ian
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't know what all is implemented on Phidgets other than reading sensors right now. I don't have a board to test/develop with, so you'd have to either add some code to RR or write a plugin.
    Ride Runner RR's Myspace
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 02:24 PM
  2. Replies: 4
    Last Post: 07-19-2006, 06:57 AM
  3. Cell Phone GPS
    By EBFoxbat in forum GPS
    Last Post: 09-14-2005, 06:45 AM
  4. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 11:02 AM
  5. OEM GPS Modules.
    By IntellaWorks in forum Hardware Development
    Last Post: 03-08-2005, 06:29 AM
