Results 1 to 2 of 2
Thread: any way for an external program to know which skin is in use?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've made a trillian skin for MC2.0 that "embeds" bother the list window and the message window on the same skin thanks to a lil auto-it scripting. The only problem i have now is if i switch to another skin then back to my trillian skin the message window stays behind rr. Is there a way i can tell auto-it to give focus to the message window if the current skin is trillian.skin? If not, can any of you auto-it gurus think of a way for a script to run a command if its opened again. I guess in a way it would be similar to preventing two instances of the same .exe, but instead be somethin like this
    Code:
    While processexists("trillstart.exe")
        If fileopen("trillstart.exe") Then
              Wingetfocus("messagewindow")
        Else
        ENDIF
    WEND
    I know "fileopen" wont work there... but is there a similar function that would work?
    Live mp3Car Facebook Chat
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can make a request for RRScreen via SDK REQUEST, and it will tell you which is the current screen in RR. The SDK example does just that. It is possible to use the same thing using the AutoIT examples.
    Ride Runner RR's Myspace
  1. Can you tell I was bored today: Take a look.
    By Sweet05 in forum RR Skins
    Last Post: 08-17-2006, 04:25 AM
  2. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 06:54 PM
  3. Skin Program?
    By Walshy in forum MediaCar
    Last Post: 01-02-2005, 02:08 PM
  4. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
