Results 1 to 6 of 6
Thread: GPS not showing up
    Constant Bitrate KennyKen's Avatar
    England
    GPS not showing up
    Hey folks,
    Im using the latest release of RR with the BMW E36 skin and i love it.
    While upgrading my PC i brought it into the house to test everything and it was all going well. i had just installed FreeDrive and when i pressed the GPS button in RR it came up with a static FD. which is goodbecause my GPS reciever wasnt plugged in.
    So i thought i would test it with the reciever plugged in, but it took a while to get the reciever working again because i lost the driver disk but eventually got in running fine.
    Except when ever i go into RR and press the GPS button i get a menu at the bottom to control music but thats it the rest of the screen is blank. Now when i use FD on its own it works fine.
    and something even stranger is that, if ive got another window open eg Internt/My Computer then whenever i press the GPS button the other indow will resize into that space...
    Here are a couple of screen shots of my settings and what happens:
    If anyone has any ideas that would be great.
    Oh ive tried deleating the RR.Ini and then adding all the settings in again but that didnt fix it.
    Cheers
    Ken
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    I don't know for sure but I thought you has to assign a GPSport number. where your's shows zero.
    May 2005
    Vienna, VA
    Try another skin. Your settings look all right.
    No you don't have to set the GPSPort for FreeDrive. In fact, you must not use the same port number for both RR and FD.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Make sure you don't have any "open" windows with FreeDrive in their title. And yes, try a different skin to verify the settings work. The skin may have a bug or something.
    Ride Runner RR's Myspace
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    I think you are using my BMW E36 skin...
    Try to delete the "GPS" definition line in "ExecTBL.ini" in the skin directory (not the one in RR directory).
    "DVD","LOAD;POWERDVD_PLAYER.skin||SENDKEY;{ENT ER}"
    "GPS","LOAD;EXTERNAL_GPS.skin;;C:\Programs file\FreeDrive\FreeDrive.exe;FreeDrive" << DELETE
    "CAMERA","LOAD;CAPTURE.skin;;C:\Programs file\Capture!\Capture!.exe;Capture!"
    England
    Quote Originally Posted by Robby BMW
    Yup thats correct im using your skin and loving it. and what you suggested worked... Your a star man, Thanks for everyones help.
  1. Replies: 6
    Last Post: 02-04-2006, 10:22 AM
  2. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  3. Replies: 8
    Last Post: 03-26-2005, 11:29 AM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
