Results 1 to 10 of 12
Thread: Road Runner visulizations Slow
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Ep1300 with 512 Ram When I click visual it seems to be slow dont know if this is just because of the ipod but when I exit road runner winamp does its milkdrop fast. Any one aware of this problem , also I get a problem the music starts then stops when it resumes then I have to plug in and out my ipod ?
    Any ideas?
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The Vis should run the same inside and outside RR. If not, you may be having CPU load issues -- check that and follow the FAQs to fix it.
    If the song that's playing is FROM the ipod, when you hibernate/resume winamp may loose the connection to the ipod which would cause it to stop. I would try NOT having itunes installed to see if it helps.
    Ride Runner RR's Myspace
    Apr 2006
    Thanks mate for all your support and support to others ill try to resolve it I was thinking it could have been todo with the usb , ill have a look at that faq i dont have itunes installed still having playlist issues i have a full 60 gig ipod mabey you want to check out the db?
    my TURBO! Altezza!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    USB stuff tends to be quite *****y when hibernating/resuming.. depends on the device.. I've been meaning to make a little program to "wait" for USB devices to wake up, so that we can run it during the resume event prior to let RR try to restore music playback and start using devices that may not yet be available after resuming.
    If your ipod works fine with a normal startup, then there's nothing wrong with the DB.. it may simply be the USB stopping/starting during the hibernate proccess.
    Apr 2006
    it does work now after some tweeking guino now it just takes a acceptable delay, still problem with my playlist , im going to format my ipod and try re loading it , but like the winamp plug in finds all the playlists and plays them fine this is why i think its a bug
    my TURBO! Altezza!
    Nov 2004
    Which skin has Visualization that runs in the RR and not in the background?
    Apr 2006
    I dont know but this fullscreen thing is running me crazy. I think i fixed the slowness installing flash but i had to iexplorer on my computer
    my TURBO! Altezza!
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by BoOsTin FD
    all of them
    beer replenishment fund
    mp3car live search
    Apr 2006
    Does any one have a solution for the milkdrop or Avs bouncing around when you double click it for fullscreen its so anoying
    my TURBO! Altezza!
    Nov 2004
    i tried couple of them and none of them actually run like they should... they run in the background or not at all
    I'm probably doing something wrong...
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  3. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  4. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 02:48 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
