Results 1 to 9 of 9
Thread: FAQ Submission: How to fix strange characters in ID3 tags
    Low Bitrate uptpilot's Avatar
    Jun 2005
    Oklahoma City
    If you're getting strange characters (F, L, L) in RoadRunner, it's most likely due to Unicode strings contained within the MP3's. I suspect this is caused by some ID3 tagging software.
    Regardless, here's how to fix it...
    1) Download ID3-TagIT
    2) Open up the directory with the offending files. Note: everything will look normal inside of ID3TagIT because it properly parses unicode strings. Don't worry about this.
    3) Hit CTRL+A to select all the files to fix.
    4) Pull down Extended Functions --> Change Tag Ver. x text encoding.
    5) Choose "ANSI Encoding" in the options that appear.
    6) That's it. You may have to separately edit the Version 1 and Version 2 tags, but by default ID3 Tag IT is synchronizing Version 1 and Version 2 tagging (Options pulldown).
    Hope this helps!
    Low Bitrate ibanez737's Avatar
    May 2005
    This is not working for me...Are those the only steps you took? What options do you have under your music settings as far as displaying ID3 tags?
    Jun 2005
    Oklahoma City
    I also made sure that I viewed both Version 1 and Version 2 of the tags in ID3 Tag. It's under the View menu and there's a toolbar button.
    In addition, it's somewhat not obvious, but remember to Save the changes. Hit CTRL+S or use the pulldown menu functions. MP3's which are waiting to be updated are highlighted in Yellow.
    After using the Convert to ANSI function described previously, it should work fine.
    Try this again and if it still doesn't work, i'll look at my RR settings.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Wink
    Google for MP3nity it does everything for you on the fly. Worth $19.95
    Elsewhere
    Other tagging utilities have the same functionality. I use Tag & Rename, personally.
    How about the Wiki?
    Jun 2006
    Thank you, solved my problems!
    Dec 2005
    Georgia Tech (ATL)
    Anyone know how to do this in Tag&Rename?
    Nevermind... I managed to find it. For anyone else that is interested:
    After I edit mp3 files tags with Tag&Rename some programs can't show this tag at all or show it incorrectly (Tag&Rename show tag data ok). What can I do?
    * Most likely this programs can't read Unicode tags, see Tag&Rename options -> "Tags" -> "Write Unicode data into ID3v2 tags" – uncheck this option. To re save tags without Unicode just select files in Tag&Rename file list and press "Save tags" button "Multi file tag editor" tab - this will rewrite tags and remove Unicode data from its. (See also "Notes about Unicode support" topic in program help).
    This might also be useful to some:
    I try to use Tag&Rename with files which contain Unicode data in file names and tags. However, when I looked at this files, Tag&Rename only displays the pipe symbol, e.g. ||||| |||||| |||||.mp3. Any suggestions please.
    * Font used in Tag&Rename interface don't have characters of this language, so go to "Program options" -> "General" -> "Interface font" and change it to font which support this language, it you have MS Office installed than change it to "Arial Unicode MS" - this font have support for most languages.
    all information found here: http://www.softpointer.com/tr_faq.htm
    Mar 2006
    Unhappy
    sorry, but this is not a solution - at least if you have already lots of files.
    Why not changing the program to read it right?
    I am working currently on a plugin which provides the id3v2 tag information without garbage (unicode byte order mark). It uses the audiogenie.ocx and wrapps currently only artist,album and title - but i will add more...
    Jun 2005
    Oklahoma City
    Thumbs up
    Quote Originally Posted by ReflexNPG View Post
    I think it's a limitation of VB6 (unicode) of which RR is programmed in.
    uptpilot
  1. id3 tags
    By doctorr in forum FrodoPlayer
    Last Post: 12-30-2004, 01:57 AM
  2. ID3 V2 tags
    By SWC in forum Software & Software Development
    Last Post: 11-27-2004, 01:13 PM
  3. Turn off ID3 tags
    By Bobby Digital in forum Media Engine
    Last Post: 06-05-2004, 04:01 PM
  4. auto id3 tags?
    By mp3z24 in forum Software & Software Development
    Last Post: 03-25-2002, 09:40 AM
  5. voice for ID3 tags
    By mp3designer in forum General MP3Car Discussion
    Last Post: 06-23-2001, 11:32 AM
