The output layer is the only thing you see and is a mix of other layers which are loaded to memory only. In most cases you'll have a button highlighted some indicators on, and others off.. RR will use the output layer to display the resulting image on the screen. If you want to change how an indicator will look ON, you can simply modify the ON layer and (whenever it turns on), it will be displayed. if you want something to show immediately, use the OUT layer. You can also make dynamic indicators for displaying different images on the same place of the skin. If you try to update the ON image of a button or indicator while the button is highlighted or indicator is on, then it won't change how the button looks until RR redraws the button/indicator. The Output layer can be used directly for that, but it only displays things until something else overwrites it.
LinkBack URL
About LinkBacks
