The only problem right now is that my video stops and goes every second. Video controls or mappoint controls go down.
CPU 100% utilization with Transition=0
Video controls or mappoint controls do not go down if: Transition=-1
Same issue with the video player here
With effects on - video controls hide, but everything slows to a crawl. CPU usage hits 100%
With effects off - video controls never hide "Full" flashes up every few seconds. Video does play OK though.
I've tried enabling/disabling effects in rr.ini, as well as individually in the video_player skin.
This is on an EPIA 13000 btw - the lack of graphics horsepower may be having an impact.
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
Just a quick update, I added a Graphics card to my M10K system and the video inside RR is still the same. Although when its just running in winamp and not in RR it is perfect. So im leaning towards it being an RR issue.
I hope this helps
Ken
Prepping for Trax in september
Re-Building the whole CarPC to upgrade all the software
Whole new boot build and moulding my screen into the dash...Again
thanx for the reply.Originally Posted by guino
i made sure i was clicking the "left" button. Doesn't seem like anything is freezing up or high CPU load. Like I earlier mentioned, it only seems like the target application is not "on top" and hence the commands are not going to it.
I noticed that my media buttons work great whenever I start RR. Once they stop working, I have to exit and restart RR. I'm using IGMon, maybe that has something to do with this ?
Flash issue for sure mate
Check out this faq here: High CPU Load, Buttons Fail to Respond, White box / square around logo's
Follow the steps there and your problem will be solved.
Thanks a lot Guino! enjoy your holiday![]()
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
Try this for the issue with the video player not hiding:
http://www.rrdownloads.net/beta/rr.exe
Ride Runner RR's Myspace
You are the man.... So far it works great if I disable the fade images and transitions/fade. Also the video is running smooth again.
fadeimages=False
transition=-1
Magic man guino did it again. - thx
You have yours with the transitions and fade?Originally Posted by Chuck
