Page 11 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 101 to 110 of 184
Thread: RR 7-8-06.. Pic Viewer & more
  1. #101
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by xs10x
    You have yours with the transitions and fade?
    I do not use transitions and fade
    EDIT just tried transitions and it worked fine
    2001 S10 ZR2
    Chucks Skin - to old
  2. #102
    Feb 2004
    Germany
    Works great here too. Very NICE
    Thanks a lot like always!
    Winni
  3. #103
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    VOL+;WINAMP", "VOL+;PREAMP" and "VOL+;FREQx" stops to work
    I've just noticed that the commands "VOL+;WINAMP", "VOL+;PREAMP" and "VOL+;FREQx" have stopped to work. Does someone have got the same issue?
    Another thing...
    Guino, I've seen that you have made all the changes I've suggested to fix the slider backstyle ranges, all except this in frmSkin.frm:
    Public Sub UpdateSliders()
    'Set Background (if any)
    If .Style <= UBound(Styles) Then
    BackPath = Replace(SKIN_PATH + Styles(.Style), "*", CStr(Value \ 3120.76))
    you have placed a different value. Is it a typo or there is a reason?
  4. #104
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I had to change it cause there were backstyles not showing with the value you posted.
    I have not changed anything with the VOL commands so it should still work, but I'll test when I get a chance.
    Ride Runner RR's Myspace
  5. #105
    Aug 2005
    Italy
    Quote Originally Posted by guino
    Thank you Guino for the flash answer, I've asked for this because with the value that you have placed in, when a level (typically BALANCE) is at 50%, it's shown the backstyle picture 9 instead of 10.
  6. #106
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are 21 backstyle images (0-20), 0 is empty and 20 is completely full so 19/2 = 9.5, so they're not that evenly distributed (seems this was a bad heritage from MC -- I just rebuilt support for the same backstyles).. but I have planned to extend backstyles to support a custom number of images.
  7. #107
    FLAC mauri's Avatar
    Jan 2004
    Question Request
    @Guino
    Any hope to have an indicator/slider implemented for monitorize the Volt of car battery with my voltmeter hardware?
    Mauri
  8. #108
    Aug 2005
    Italy
    Are you sure? Look at the picture below:
    How you have said, the backstyle images are 21 (0-20) so when we get a level of 50% (for example when the L/R balance in central position), the right image to be shown is the number 10.
    The value of 3120.76 that I've suggested is the result of the calculation:
    65536 (the value equivalent to 100%) / 21 (the number of backstyle images).
  9. #109
    Mar 2006
    Shouldn't the last image be gif_20?
  10. #110
    Aug 2005
    Italy
    Quote Originally Posted by sandworm
    Sorry
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 09:13 PM
  2. OK a viz that works fullscreen with RR
    By accentsound in forum Road Runner
    Last Post: 01-09-2006, 11:45 PM
  3. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  4. Tripex3 in RR
    Last Post: 07-21-2005, 08:09 AM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
