Page 4 of 19 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 184
Thread: RR 7-8-06.. Pic Viewer & more
  1. #31
    Mar 2006
    gnarcor: just unzip the binary package over wherever you installed roadrunner and have it overwrite all the files.
    Is anyone else getting a problem where the video player won't auto-hide the toolbar interface? I'm using the built in mpc and it just keeps displaying the current aspect ratio OSD every 4 seconds (the same timeout that the interface should be auto-hiding)
  2. #32
    May 2006
    menifun,ca
    k i did that but everythings the same no tran effect or pic viewer
  3. #33
    Mar 2006
    you need to modify your skin to take advantage of the new stuff.
  4. #34
    May 2006
    menifun,ca
    ohh yeah cause the only one i have is bmv2 which one will work with it?
  5. #35
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    To see the transition effects on your current skin, simply add the following line to your RR.ini:
    transition=0
    0=Fade, 1-9=Different Slide/Clipping effects), 10=Random (between 0 and 9)
    Jarrod - Holden VX S!
  6. #36
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Sweet05
    I am fairly new the skinning and do all my work in the visual skin editor and I can't figure out how to use the text editor to add the /EFFECTXX tag to my skin I have tried a few different ways but it always uses the default.
    unfortunately these specific tags dont work with the skineditor, soon as you add them it deletes them before you can save. So you will have to use notepad to add the tag. But after that you cant open and save the skin with the skineditor cuz it will remove the tags again.
    There is an objects.txt file in the skineditor that lets you add new objects but i havnt figured out how to add these new tags yet cuz they are different than other rr commands/tags etc.
    beer replenishment fund
    mp3car live search
  7. #37
    Constant Bitrate Sweet05's Avatar
    Apr 2006
    I know this. My first post was worded poorly. How do I add them with a text editor was the question not will they work with skin editor.
    I mean where in the skin file do they go?
    How do I format them?
    Does the number have to be two characters as the documentation implies "/EFFECTXX"?
  8. #38
    Aug 2003
    Chicago
    you can add them anywhere you want, end of the file is good place, before the END tag though.
    /EFFECT0
    cant remember if you have to use both X's if its only single digit, just see which one works.
    This is an example, this isnt the full .skin file but just the last few commands at the bottom of the file.
    Code:
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,94,120,403,195,192,192,192,0,0,0,255,255,0,193,0,0,0,0,0,TRUE,18,"Arial Narrow:B"
    /, J, x, y, w, h
    J,507,127,206,187
    /, A, x, y, w, h, color;RGB
    A,507,127,206,187,
    /EFFECT0
    END
    mp3car live search
  9. #39
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by Wal
    Blaupunkt Selfmade Twin-Tuner Radio for RoadRunner
    Here the Softwarelink :
    http://www.yourfilelink.com/get.php?fid=133188
    And here the Hardwarelink with Layout and more :
    http://www.car-pc.info/phpBB2/viewtopic.php?t=8871
    Wal
    can you explain a little more.. the page you link is in German... can't read it..can't even find the schiamatics.. i would like to know more.
  10. #40
    Apr 2006
    Thanks LS I tried that exact method but it still just faded in and out I have transition=0 in the rr.ini do I need to remove this??
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 09:13 PM
  2. OK a viz that works fullscreen with RR
    By accentsound in forum Road Runner
    Last Post: 01-09-2006, 11:45 PM
  3. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  4. Tripex3 in RR
    Last Post: 07-21-2005, 08:09 AM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
