Page 6 of 19 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 184
Thread: RR 7-8-06.. Pic Viewer & more
  1. #51
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by Enforcer
    OK stand corrected, however a bit more explanation at the time would have been useful, instead of just dumping a couple of links (especially as one was all in German)
    I agree..
  2. #52
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    awesome... I really pray for full DVD support (no more embedded mplayer classic window)
  3. #53
    Wal
    Wal is offline
    Newbie Wal's Avatar
    Jun 2005
    Germany
    @Nomander,
    no lausane CD 31 is not work, look in the list.
    You can not buy that Radio, it's Selfmade.
    Wal
    Commell LV-673, Pentium M 2GHz 533FB, 1024MB RAM, 40GB 2,5'' Festplatte, Pioneer DVR-K05 DVD, Soundblaster Live 24-Bit USB, Hami 8'' TFT, Velleman K8055 I/O Card, Selfmade Blaupunkt TwinTuner Radio
    GPS: "MapFactor PC-Navigator 7"
    Frontend: "cAVe_Live"
  4. #54
    Apr 2006
    Greece
    Quote Originally Posted by LagunaICE
    why don't you try Power DVD.. I have it working perfectly with RR
  5. #55
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Some observations on the pic viewer.
    1. if you click on the file list it loads the pictures into your playlist. Not good.
    2. the image seems to be squashed into almost a square. is it not possible to either keep the correct aspect ratio or stretch to the dimensions indicated in the skin?
  6. #56
    May 2005
    Vienna, VA
    I'm gonna put in my requests on the picviewer, too.
    1. Ability to scale all pics up by 125% in height for those running 7in. widescreen LCD at 800x600.
    2. Fullscreen capability like video_player.skin (ie. HIDECONTROLS -> fullscreen. Tap on image -> back to windowed mode).
    3. Slideshow with configurable delay (is it there already?)
    4. Zooming on image and touch-scrolling
    5. Loading an entire folder including images in sub-folders into a "playlist" of some sort (similar to audio_browser.skin)
    6. On the same note, ability to load a picture "playlist". for example, an external script can automatically load the content of a flash card into a playlist, then load the playlist into RR picviewer.
    7. Rotating image
    8. Thumbnails on the file list.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  7. #57
    Feb 2006
    Crystal, MN
    Can someone post their picviewer.skin file?
    I seem to be having problems getting the pictures to view in the menu.
    Thanks.
  8. #58
    Constant Bitrate Sweet05's Avatar
    Apr 2006
    Here is a functional skin screen it is not very pretty but it works the three main components you need for it to work are a directory list in the skin file and either a picture indicator (new) or an album art / application image object. And also a definition for the path to the pictures in rr.ini (example picspath=my pictures are here)
    PicViewer.rar
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mnmis
    Thanks.
    just make a copy of your skinbrowser.skin and rename it picviewer.skin and change UP and DOWn to NEXTPIC and PREVPIC
  10. #60
    Apr 2006
    Yeah that would do the trick then just add the line
    picspath=path to my pictures
    to the rr.ini and a button some where that has the command "PICS"
    Then you are up and running with a quick testing screen.
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 09:13 PM
  2. OK a viz that works fullscreen with RR
    By accentsound in forum Road Runner
    Last Post: 01-09-2006, 11:45 PM
  3. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 10:32 AM
  4. Tripex3 in RR
    Last Post: 07-21-2005, 08:09 AM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
