Results 1 to 6 of 6
Thread: Pic viewer How to setup??
    Nov 2004
    Can someone point me in the right direction how to setup a picture viewer... I have the spaced out skin and it has a picture feature, but i dont' know really how to configure it to display picture within the skin....
    FAQ's doesn't have anything and searching got me nowhere....
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    rr.ini... add picspath=Path to your pics. If you have a skin that uses it thats all you need to do.
    Live mp3Car Facebook Chat
    Constant Bitrate Sweet05's Avatar
    Apr 2006
    As Sonic said you need to set the path in rr.ini but the skin you use needs a few things. One is a file named "picviewer.skin" This file must have a directory list and an indicator for pictures (new) or an albumart/application image object. Two a button somewhere else in the skin that opens the picviewer.skin with the command "PICS"
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    easiest way to make the skin file is to copy the skinbrowser.skin and rename it picviewer.skin and change UP and DOWn to NEXTPIC and PREVPIC
    Apr 2006
    Yeah that would do the trick then just add the line
    picspath=path to my pictures
    to the rr.ini and a button some where that has the command "PICS"
    Then you are up and running with a quick testing screen.
    Nov 2004
    Got it... Thanks.
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  2. Screen Transitions, Pic Viewer & Album Art effects
    By DiNASTY in forum Road Runner
    Last Post: 07-18-2006, 12:30 AM
  3. Need help with PIC circuit
    By flipster125 in forum Hardware Development
    Last Post: 04-07-2006, 07:51 PM
  4. Ok setup? What Power supply?
    By untal3nted1 in forum General Hardware Discussion
    Last Post: 01-01-2005, 07:17 PM
  5. Carputer setup critique?
    By carterparks in forum General Hardware Discussion
    Last Post: 12-30-2004, 12:08 PM
