Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Multiple Soundcards - Volume Control...
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try this one for the soundcard issue (doesn't have the Dim statement):
    http://www.rrdownloads.net/beta/rr.exe
    Ride Runner RR's Myspace
  2. #22
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    Hey Guino,
    The Beta RR worked! My USB soundcard was #4 in the RRConfig list apparently, and it now works!
    Now the only problem is, whenever I close the second instance of RR, it sets my soundcard wave line level to zero so my first RR instance can no longer be heard. I'm guessing there is some code in the exit procedure somewhere causing this.
    We're getting there!
    Jarrod - Holden VX S!
  3. #23
    Jan 2002
    Melb, Australia.
    OK, I think I found the mute problem, but again, not 100% sure if this is whats causing it:
    The mixer seems to be getting closed BEFORE the line is unmuted in the shutdown sub. This would cause the DoMute call to happen on the default sound card, which would infact mute, rather than unmute.
    Code:
    'Close Mixer
    If hMixer <> 0 Then mixerClose hMixer: hMixer = 0
    The line above needs to be called AFTER this line:
    'UMute Sound (if we muted it)
    If ExitMute And Not VOICE_ON Then DoMute MasterVolMap
    I'm guessing the above comment is meant to say "UnMute" not "UMute" too.
    Think that would solve the muting problem?
    EDIT: I added the line "ExitMute=false" to RR.ini (second instance) and it fixed the problem, because of course neither of those mute commands on shutdown would be called. So that just convinces me more that the above lines are indeed causing the bug.
    Should I start another thread re: the multi-instance video issues?
  4. #24
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'd say so, though not sure when I'll ever get to it.
    I also need to change that shutdown procedure to only mute winamp.
  1. Fader, Balance, Sub Volume Control w/o Headunit or EQ?
    By The unL33T in forum Input Devices
    Last Post: 03-24-2009, 02:23 PM
  2. Roadie Volume Control
    By tjp12100 in forum FrodoPlayer
    Last Post: 06-21-2006, 03:30 PM
  3. volume control
    By JaxPt in forum Software & Software Development
    Last Post: 04-21-2005, 06:44 PM
  4. Volume control in Xenarc 700TSV
    By BMW-7 in forum LCD/Display
    Last Post: 04-06-2005, 11:08 PM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 10:43 AM
