Results 1 to 8 of 8
Thread: bass boost
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    bass boost
    ok, i have lots of mp3s (like most of us here) and a lot of the songs fall into the either 1 of these 2 categories: needing bass, and not needing bass. my idea/suggestion/request is to add some sort of indicator/button (preferably indicator so that we would know when its on and when its off) that would automatically boost the bass level up to 100% or even at a user specified value. if this is confusing to someone lemme know and ill try to explain it better. -basically, itd be nice to have a button to boost bass up for rap or hip hop or rock, and then have the same button drop the bass back down for country or slower songs or whatever.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's exactly what mixer presets are for.
    Ride Runner RR's Myspace
    Feb 2006
    Is there a way I can have the Master "Bass" and "Treb" settings programmed in an ini file. I searched for it and couldn't find anything related to that.
    The problem I have is that whenever I quit RR or restart it loses these settings and I have to set it manually everytime. If my system doesn't crash and I hibernate like I should then the settings are restored properly.
    Mar 2006
    Houston, TX
    Quote Originally Posted by guino
    gotcha, now i just have to figure out how to do that. i figured there already was a way to do this. time to some more!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Mixer presets are an easy way to do both things you guys talked about here.. But not all skins have support for those directly in the skin (doesn't mean you can't use it, or add it to the skin). The easiest way to test this feature is to load one of the Brushed skins, go into the mixer, set the EQ/Volumes the way you want then press and hold one of the buttons on the left (i.e. Rock -- to save the preset), then change the EQ/Vol settings and quick tap the same button -- you'll notice it will revert to what it was before. You can save as many presets as you like and load them whenever you want.
    Feb 2006
    I tried that guino, but that only remembers the "Winamp Equilizer" settings section. I want to keep the settings from the "Master" section (Using the BMV2 skin). Those don't seem to get saved.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Read skin commands.txt, it can do just winamp, just the mixer or both.. it's just a matter of using the right command.
    Feb 2006
    I figured out why the Mixer Presets wasn't saving my Master Bass & Treble settings. Its 'coz my integrated sound card doesn't support those features
    Looked at the code, and saw that when those settings are not found the indicators are not updated on a Load_Preset. Now that little extra Bass I thought I heard must all be placebo
  1. How do you control Bass??
    By PhatMo in forum Car Audio
    Last Post: 06-16-2006, 11:09 PM
  2. bass boost?
    By Bboy_jon in forum Centrafuse
    Last Post: 05-18-2006, 05:38 PM
  3. Audigy 2 Value - Adjusting bass crossover
    By Gazza in forum General Hardware Discussion
    Last Post: 10-05-2005, 01:56 PM
  4. Controlling fade, balance + bass idea...
    By Scouse Monkey in forum General Hardware Discussion
    Last Post: 12-10-2004, 07:22 PM
  5. MP3's bass is too flat
    By Nicorolla in forum Software & Software Development
    Last Post: 11-05-2004, 09:13 PM
