Results 1 to 4 of 4
Thread: Volume issues
    Constant Bitrate BLK MAJK's Avatar
    Jan 2006
    Toledo, OH
    Volume issues
    Hey all, I seem to be having 2 weird problems with volume in RR.
    First, if I click on any of the volume up or volume down buttons (skin doesnt matter) The volume always goes down to almost 0. The display will say its at like 95% but you cant hear it. The only way to get it back is to use the volume up button numerous times to get it back to a hear-able volume. Then all of my settings for the line-in, AUX, etc. go back to 100 (see below) Any ideas?
    Second, I have a huge difference in quality and loudness between my mp3's and XM. If I configure the EQ for my mp3's then go to XM is really quiet and sounds crappy. and its the same vice versa. I have to turn down the line in on the EQ for my XM because I get a crackling in the speakers if I leave it all the way up (any ideas on this one?) Anyone got any ideas?
    As of 4/15/06: Computer is in and running great! Still got a few bugs to work out tho
    M10000, Lilliput, M1-ATX, Slot DVD, 40 GB HDD, 512 MB DDR, BU-353, M$ S&T '06, XMD1000
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Look in the RR config and change the type of volume that it changes. There's quite a few options. Try either master or wave.
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    I've just begun to have the same issues. I'm using the new beta that fixed the video issue. None of the hardware has changed (it's been working for months without a problem which is why I decided to mess with it )
    I've tried changing which line is mapped, turning on then off the winamp eq all to no avail. I can't even hear XM at all?!?!
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There were no changes done to the volume control support in the latest release. If anything, verify that your RR.INI does not have a soundcard= line in it, and if you want to be sure, load the previous version again. Most likely some mixer/system settings were changed that's causing the issue (if it ever worked right in first place).
    Ride Runner RR's Myspace
  1. Volume issues
    By RichardB in forum Road Runner
    Last Post: 12-02-2006, 10:30 PM
  2. Insignia MP-101 cd and usb volume issues PLZ help me
    By vibez in forum General Hardware Discussion
    Last Post: 03-03-2006, 01:10 PM
  3. Frodo take3 volume issues after hibernation
    By Will Albers in forum FP Bug Reports
    Last Post: 02-01-2006, 08:02 PM
  4. Mini Volume Issues
    By mdorsey0 in forum MacCar
    Last Post: 10-07-2005, 05:03 PM
  5. Sound Volume Issues
    By ether in forum Media Engine
    Last Post: 08-02-2004, 01:24 PM
