Results 1 to 10 of 12
Thread: RR is starting to get really slow
    Banned JagPuter's Avatar
    Apr 2006
    My Garage
    I have used RR for some time now and just recently it has become a DOG as far as speed goes. I dont know what is causing this but it is kind of annoying.
    I have a MII 1200 MOBO, 512mb ram, running XP with the MC 2.0 skin and my MC skin mod. Screen switches just seem to lag especially when using the CFX skin.
    Any ideas would be greatly appreciated...
    Thanks in adavance
    Dec 2005
    Quote Originally Posted by JagPuter
    Thanks in adavance
    just noticed the same.. i have the same specs with lsx void.
    s1
    Feb 2006
    I started seeing some intermittent slowness with the addition of transitions.
    Some of this lag seems to be skin based - and since I try everything and go back to BMV2, I haven't seen noticeable slowness recently.
    FLAC djmickyg's Avatar
    Feb 2004
    i think the trasitions was a waste of an ad on. .it doesnt really look that good and it going to slow it down a lot
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by djmickyg
    So disable them
    Apr 2006
    My Garage
    Quote Originally Posted by 0l33l
    So disable them
    and how can I do that..
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    just place this in you RR.ini file
    transition=-1
    The road is long but we are getting there.
    Apr 2006
    Is anything enabled in RR which is not hooked up to your system? e.g. Phone control, XM, GPS stuff can lock up or slow things down when RR is looking for data for it and it's not getting anything.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Our Epia boards simply aren't powerful enough to run the transitions fast enough. Part of this is due to VB6, you may get better graphical effects if you were using DirectX for the graphics effect.
    Also I've noticed the bigger flash skins get a bit slow. You may want to bump your RAM to 1GB or look into optimizing your XP install. Regardless you can always shut off transitions in RR.
    What you really need is a graphics processor or more powerful hardware. But honestly what we're using now is sufficient enough since our main focus should still be on driving the vehicle.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Apr 2006
    My Garage
    Ok I DISABLED transitions and all seems to work GREAT but my flash gauges seem to not be transparent anymore. Example below. What is the cause of this crazy problem.
  1. RR really slow and unresponsive..
    By Pheebs'67 in forum Road Runner
    Last Post: 01-04-2006, 12:25 PM
  2. need some hand holding - iGmod in RR
    By Will Albers in forum Road Runner
    Last Post: 11-22-2005, 10:03 PM
  3. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 01:47 AM
