Results 1 to 7 of 7
Thread: Code to start Programs when RR starts
    Apr 2006
    I set RR as the Shell so now my programs in Startup Folder do not launch. However, I need Igmon and yahoo Widgets to start but i cant seem to get the ONSKINSTART to work.
    I been messing with the ONSKINSTART command in the EXECTBL.ini file (in skin folder).
    currently it has this command
    "ONSKINSTART","RUN;LSTOOLS\welcomeMSG\welcome. exe"
    Can anyone explain to me why if i add more lines underneath it wount work.
    "ONSKINSTART","RUN;LSTOOLS\Igmon\igmon.exe"
    "ONSKINSTART","RUN;widgets.lnk"
    Appreciate some help. =)
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Use regedit and launch them from the registry.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    May 2005
    Vienna, VA
    wave, try this.
    Code:
    "ONSKINSTART","RUN;LSTOOLS\welcomeMSG\welcome.exe||RUN;LSTOOLS\Igmon\igmon.exe||RUN;widgets.lnk"
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Apr 2006
    hey thanks for the replies. I used the posted code. It loaded the igmon. The widgets didn't load. i'm thinking because its a shortcut command. I'll mess with it some more. I think not running explorer might of affected the igmon though, loads with zoom errors, but i never encountered this before. Thanks again, i'm just happy i know how to use the code better. Didn't know you could stack it with the "||". thanks again!
    Aug 2004
    Germany
    Quote Originally Posted by IntellaWorks View Post
    How do I do that ?
    Low Bitrate rjankowski's Avatar
    Oct 2006
    TN/KY Home is Houston
    It works!!
    Almost all of the time too!
    Aug 2004
    Germany
    1st: I found this thread by searching .
    2nd: I don't want to know how to run another programm as shell, I know how to do that.
    I want to know how to launch other additional programs at startup.
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 09:13 PM
  2. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  3. Stand-alone programs (no installation needed)
    By d_sellers1 in forum Software & Software Development
    Last Post: 07-19-2004, 08:45 AM
  4. Replies: 4
    Last Post: 06-29-2004, 09:20 PM
  5. How do i start a program when windows starts its shutdown rutines
    By darkwingduck in forum General Hardware Discussion
    Last Post: 12-10-1999, 07:28 AM
