Results 1 to 5 of 5
Thread: Different Radio idea/help
    Jul 2006
    I'm starting to organise myself a carpc and I want to do without a HU.
    I've done plenty of searching about the FM radio solutons, but I only listen to one station for the drive-time shows.
    So my idea is to get/make an FM tuner with reception comparable to a HU and tune it manually to the station I want, so when I select radio I want RR to pause the mp3 playing abd un-mute the line in from the fm tuner.
    Is there anyway I could get this to work? I know the PAUSE command, but dont know about any line control commands.
    I dont mind hacking a little fm radio, but I need to know it will handle travelling, any suggestions or are most battery powered fm radios ok on the move?
    Cheers.
    Paul.
    Jul 2006
    I've done some more seaching, and looking through the the skin commands.
    I see where I can cycle the mute state of any line in windows, but I cant see a way to unmute or mute irrespective of the current state.
    eg. say it is already active and I send the command to unmute, then it would stay as it is.
    Paul
    Also is it likely I will be able to have the line-in muted for GPS directions and Phoco?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    interesting idea... i always wanted to unmute when i press volume up! but not to unmute with volume down
    Jul 2006
    Right now I'm looking at using radiator but obviously only with the line in source, not a real tuner.
    But I cant find my male-male 3.5mm audio plug to test it right now.
    Jul 2006
    well after mucking around a bit last night I managed to get it working with radiator, even though it does nothing other than open and mute line-in.
    Now I'm trying to find a solution to waking the computer at a certain time while i'm not in the car to record a radio show.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  3. how can i use my existing old school am radio controls
    By 72chevyPickup in forum Car Audio
    Last Post: 01-11-2006, 10:33 PM
  4. wintv radio not launching when i press radio
    By dnkyntz in forum RR Bug Tracker
    Last Post: 12-23-2005, 01:49 AM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
