Results 1 to 6 of 6
Thread: Problems embedding GPS application properly
    Jul 2006
    I've read all the faq's and searched all the posts and can't get this to work right. I'm embedding street atlas 2004 into my skin but I'm having problems getting it to "stick". I can get it to open my GPS skin and start SA from the menu, but SA always opens to whatever size I had the window set to previously (usually full screen). I end up with a clipped RR window overlaying a full screen SA program that is in a seperate window. Also, if I close or exit the GPS.skin, it appears to close SA and if I then click on the GPS button again it doesn't re-open. And, in Task Manager it still shows StreetAtlas under the processes tab. What do I need to do to get it to embed in the RR window? Here's how I have it setup:
    MENU Skin line:
    B03,120,307,385,92,"LOAD;GPS.SKIN;RUN;C:\Program Files\Street Atlas USA 2004\SA2004.exe;!DeLorme_SA2004_0"
    GPS.skin file:
    MEDIACAR Skin
    MEDIACAR Alpine Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,230,587,128,49,"CLOSE",""
    B02,230,655,118,49,"EXIT",""
    /, C, x, y, w, h
    C01,160,0,866,565,192
    END
    Also, I want to keep SA running in the background when I switch to audio or video or whatever else. I don't want it to have to reload every time I go to the GPS skin. How can I make this happen? What is the difference between the EXIT command and the CLOSE command?
    Do I need to do anything special to make the SA application close when I exit RR or will it do so automatically?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    beer replenishment fund
    mp3car live search
    Jul 2006
    Quote Originally Posted by Enforcer
    you need an A line (A for application)
    A01,160,0,866,565,192
    Ahh. Thanks. I had changed it according to the "how to" I read (same as above)....to a 'C' in order to clip that area. Looks like that was the problem. Otherwise, should the application (StreetAtlas) continue to run unless I close RR?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Tim K
    The app should run until RR closes. just make sure you have closeapps=true in rr.ini
    Jul 2006
    thanks for the help....I'm getting there....slowly!
  1. Linux Vector GPS Application
    By strandtc in forum Linux
    Last Post: 01-25-2007, 03:37 PM
  2. 1.7 Progress report
    By veetid in forum Centrafuse
    Last Post: 04-28-2006, 11:14 AM
  3. Problems with GPS mouse and XMPCR
    By DaveDog in forum GPS
    Last Post: 06-11-2004, 01:04 AM
  4. Deluo GPS w/PDA problems
    By wizardPC in forum GPS
    Last Post: 05-20-2004, 02:18 AM
  5. deluo gps driver problems plz help!!
    By BobbyD in forum GPS
    Last Post: 04-29-2004, 06:18 PM
