Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: RR and Iguidance v3
  1. #41
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    ig native is built into the RR install - take a look through the rrconfig from bluezx3
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  2. #42
    Newbie halestorm's Avatar
    Nov 2009
    Quote Originally Posted by sargeants View Post
    ok. Yeah, I saw that (I'm using the 12/2/09 version) but it didn't make any difference whether iGnative was checked or not. I mean, it works, and it looks "ok" but would be nicer if it didn't have its menu bar which makes it look like a windows program is running rather than a native nav.
    I did find that there is a "GPS" button from the Sirius screen (why, I don't know). When using this then it gets rid of the menu bar. I discovered this late last night so I have yet to look into what's different, but the answer is probably in there.
    Dave
    http://www.evalbum.com/2500
    almost no reason to burn gasoline anymore
  3. #43
    Oct 2008
    Ontario, Canada
    I think you need to double check some settings.
    first - window name should be 'iGuidance' - small i, big G
    second - what skin are you using?
  4. #44
    Nov 2009
    1: Yes, it was iGuidance.
    2: skin = simplistique
    The answer was in calling the application. Apparently you have to call it with just the "GPS" command in order to utilize the now-built-in ignative, which also uses the external gps skin (instead of the iguidance skin). I was calling it with "LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;!Intellinav WCls!iGuidance"
    It's all detailed more on this thread which I also posted to.
    tnx,
    Dave
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 04:17 PM
  3. embedding iguidance in RR
    By vfinterceptor in forum SkinBedder
    Last Post: 04-25-2006, 02:41 AM
  4. iguidance in RR
    By sergatiuk in forum Road Runner
    Last Post: 03-06-2006, 06:00 PM
  5. Iguidance Double instances in RR
    By wariow in forum Road Runner
    Last Post: 09-09-2005, 10:43 AM
