Results 1 to 10 of 15
Thread: Changing back ground colour
    Constant Bitrate Paul C's Avatar
    May 2004
    West Sussex
    Is there a way of changing the back ground colour in RR so you can have a light back ground in the day and dark at night? a bit like map monkey has. I know you can have day skin and night skin but when it changes it kinda restarts everything. And I know of gamma control but that kinda of washes out the colours.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    you mean like a day and night skin?
    ......yes
    PC Components:
    My work log
    May 2004
    West Sussex
    Quote Originally Posted by Peoples
    ......yes
    ok so how?
    May 2005
    Vienna, VA
    You edit the skin images directly. You got 2 options. 1) Do it yourself with Photoshop/Gimp/whatever image processing app you know. 2)Beg the skin creator to make one for you.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    May 2004
    West Sussex
    I have created my own skins I have a day one and an identical one for night only with a darker background. What i'm asking is, is there a way to change the background with out loading a new skin
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Smile
    Hello Paul,
    you can use a gamma button like so
    B26,211,379,189,89,"GAMMA",""
    Cheers KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    May 2005
    Vienna, VA
    The short answer is no.
    The long answer is yes, there's workarounds. You can use the LOADIMG command to load a different background onto your skin. Or you can use Flash and change the background dynamically like the MC2.0 skin.
    May 2004
    West Sussex
    Quote Originally Posted by kpjuk
    Hello Paul,
    Cheers KPJUK
    so what will that command do?
    Dec 2003
    West Midlands
    Hello Paul,
    it gives a dimmed effect, by changing the brightness I think. It takes the brightness out of a skin for use at night. A number of skins have this button featured, try BVOA http://www.stonewaresystems.co.uk/lack-Al-betav4.rar
    Fire up the skin and hit the bottom right button to get the main menu. Then hit the Day/Night button and see the difference.
    Otherwise just add a button to your favourite skin and give it the comman GAMMA.
    cheers
    KPJUK
    May 2004
    West Sussex
    Hello Paul,
    cheers
    KPJUK
    Like i said in my first post I'm not struck on using gamma control because the colours get all messed up and if you have it changing the skins you have to restart every thing like the GPS etc
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 02:36 AM
  2. Ewww, ground noise finally isolated, now wut!?
    By sdashiki in forum Car Audio
    Last Post: 04-01-2006, 01:21 AM
  3. Ground loop with an external USB card?? Help! (LONG)
    By vettejock99 in forum Car Audio
    Last Post: 02-05-2006, 10:20 AM
  4. Ground noise in system
    By TyBong in forum General MP3Car Discussion
    Last Post: 09-20-2005, 02:13 PM
  5. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 07:54 AM
