Results 1 to 8 of 8
Thread: .FLV video format in RR
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Does or will RR support .FLV video playback??
    I am asking because the flash based video format is one of the most polpular on the net now (ex: youtube.com)
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Raw Wave
    Jun 2004
    On the beach
    If you can find the codecs compatible with mplayer then RR supports it
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    i found the fix for the video there is a VIDEO file association in the RR.ini
    videofiles=.mpg,.mp4,.flv,.avi
    adding the above line under the [video] options worked and fixed the .flv issue now i can watch all the youtube videos i want (pinkfloyd synced with the wizard of oz, how can you miss out?)
    also there is a spot in the RRconfig on the video tab, my eyes overlooked it till i was here "focused" at work
    ALSO use media player classic from the klite codec pack and you will be golden
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    you gotta add the line eric said
    but you gotta have some .FLV codec installed too
    i'm currently using CCCP (Combined Comunity Codec Pack)
    it maker almost any player rum almost any format. the only one i've missed so far is the .rmvb wich can be player with the RealAlternative Codec.
    []s
    Mar 2007
    ohh yeah i forgot to talk about the codecs
    google "klite codec pack" it comes with mplayer classic and its the ONLY codec pack i have ever needed GREAT player!
    Oct 2007
    Sorry to post in these thread, I also have the same problem. I have installed the latest klite codec and add the line above to rr.ini, but still no go. I can play the flv video in window, but when I run rr while flv playing, it's stop and a little message on the bottom of embed mpc said "file can not find". It was working b4 with dfx3, this happened after I upgraded to the latest official rr version and dfx4. Any help and advice much appreciated.
    Anchim
    Feb 2007
    netherlands
    i even play mkv files, i am using the mediaplayer clasic that that came with the k lite pack. But flv was playing with the mediaplayer that came with RR, to bad the mkv didn't.
    Think your codec's are wrong. Just download a k-lite codecpack (a full version) and it should work fine.
    Oct 2007
    Quote Originally Posted by rijk View Post
    Thanks for your reply, I can played flv fine without rr running. as soon as I run the rr, it stop working. I am using k-lite full version. I found a thread someone here suggested by changing .flv to avi extension. I tried it and it works. If anyone have these problem, give this trick a try. Thanks for all the help
  1. RR Video does not play all videos
    By Lyzdog in forum Road Runner
    Last Post: 01-18-2006, 08:23 AM
  2. rr & winamp play same time/different videos?
    By turbocad6 in forum Road Runner
    Last Post: 01-12-2006, 03:40 AM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
  5. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 12:33 PM
