Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: So overwhelmed with iguidance and RR right now *simplistique skin*
  1. #11
    Newbie halestorm's Avatar
    Nov 2009
    Quote Originally Posted by ignatz42 View Post
    JohnWPB - I was able to get iGuidance to embed using the strings you gave with one hiccup. When I embed iGuidance directly, I can use the Simplistque skins to send commands (like Mute). When I embed iGuidance using iGLaunch using the string you provided, the skin buttons don't work. If I use the following line in menu.skin:
    B06,400,217,380,84,"LOAD;IGUIDANCE.skin;iGLaunch;C :\Program Files\iNav\iGuidance\iGLaunch.exe;!TForm1,!iGLaunc h",""
    the skin commands work sporadically. My question is do, you know how to both embed iGuidance (so the status and menu bars are hidden) and pass the skin commands at the same time? Thanks in advance.
    so, blast from the past . . . these original posts are over 3 years old but here I am running iGuidance (and I happen to also be using the Simplistique skin at the moment). It works (mostly) but I would like to get rid of iGuidance's menu bar. The links for iGLaunch all seem to be dead now. Is there another way?
    Also, the buttons at the bottom of the screen don't do anything (when in iGuidance).
    Dave
    http://www.evalbum.com/2500
    almost no reason to burn gasoline anymore
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I think what you want to do is set ignative=true in RR.INI/RRConfig... can u verify you're using that?
    Ride Runner RR's Myspace
  3. #13
    Nov 2009
    Quote Originally Posted by guino View Post
    Yes, I am. Though as I say I've tried it both ways and it makes no apparent difference. Here's the present, relevant section from my rr.ini:
    Code:
    [GPS]
    gpsmode=2
    mapmonkeypath=Click here to set path
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    overspeed=55
    gpsport=2
    mappointmap=1
    mapcountry=United States
    mapcity=Los Angeles
    mapautozoom=false
    isunits=false
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    ignative=true
    igautosw=true
    gpsonvoice=true
    pauseonvoice=false
    lastscreenswitchtime=0
    But the answer is in the skin. As I say, it looks "native" when called from the Sirius page. The Sirius.skin file calls this:
    Code:
    B20,206,165,64,84,"GPS",""
    whereas the menu.skin calls this:
    Code:
    B06,540,212,300,80,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;!IntellinavWCls!iGuidance",""
    So my guess is that the command "GPS" is something built into RR now, perhaps? I can probably just move that to my menu.skin and be done with it.
    tnx,
    Dave
  4. #14
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Look in your exectbl.ini file in your skin folder for this line.
    Code:
    "GPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance"
    Now you can change the buttons to "GPS" and it will call the skin and start navigation.
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    FYI
    When using the built in "GPS" cmd with the "GPSMODE=2" setting, it will load the External_GPS.skin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    Nov 2009
    Quote Originally Posted by MGD View Post
    Code:
    There is no such entry in my exectbl.ini; the GPS command must just be built in.
    Dave
  7. #17
    Nov 2009
    Thanks Blue, this is what I wanted, as it also starts it without the menu bar. Where is the GPS command defined? (It's not in my exectbl.ini.)
    Dave
  1. RR and Iguidance v3
    By kjones2k1 in forum Road Runner
    Last Post: 12-17-2009, 04:35 PM
  2. Replies: 570
    Last Post: 11-05-2009, 02:49 PM
  3. Replies: 17
    Last Post: 09-04-2006, 12:33 PM
  4. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 03:17 PM
  5. iguidance in RR
    By sergatiuk in forum Road Runner
    Last Post: 03-06-2006, 05:00 PM
