Results 1 to 10 of 17
Thread: So overwhelmed with iguidance and RR right now *simplistique skin*
    Newbie BavarianBuilt's Avatar
    Jul 2006
    Clifton, Virginia
    hey everyone, I'm looking for some help. I've searched the mp3car forums for the past week and tried everything to my knowledge but I just can't get iguidance to work in road runner. Here is where I'm at so far. I've got iguidance v3 and I'm running the UMPC version. I've got the lastest road runner version and I'm using the simplistique skin. I've tried making changes to EXTERNAL_GPS.skin, menu.skin, everything. I've got the gps path and window name correct in RRconfig. What am I missing? I've read alittle on skin bedder, but I just can't figure out how to run iguidance in the simplistique skin. If I run the BMV2 skin that comes with the RR download, it launches iguidance, but in its own window. TIA guys. I've been a long time lurker at this site, figured i'd start posting
    Gary
    Jul 2006
    Clifton, Virginia
    BINGO! got it working. My next question on this topic. When ever I hit a navigation button in roadrunner, my windows bar appears at the bottom of the screen showing my current running programs. If i hit Road Runner, it goes back to full screen, but the second it does something with iguidance, it comes back. I don't mind it THAT much, but was wondering if there was a way to make this go away?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    can you pase your gps settings in rr here? I have iguidance with simplistique working fine.
    Mar 2004
    Im having a little trouble with simplistique and iguidance 3.0, too (though I dont think it's related to the skin). When I hit the gps button, iguidance doesn't start at all. I have the same exact settings on my desktop, and its working fine there. I dont really have any idea why it's not opening up on the carputer
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Loading IGuidance in the Simplistique skin
    Here is the code I have on my menu button in Simplistique's skin to launch IG. It works perfectly here:
    B06,400,217,380,84,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance",
    That was the original unaltered skin, as I just tried it and it works fine.
    If you want to remove the borders and menu bar from IG download IGLaunch and use the folloowing line instead:
    B06,400,217,380,84,"LOAD;IGUIDANCE.skin;iGLaunch;C:\Program Files\iNav\iGuidance\iGLaunch.exe;iGLaunch",
    You would also need to change the settings in RR config to poin to iGLaunch instead of dirrectly to IG, as well as the window tile to "iGLaunch"
    Hope this helps out...
    NOTE: The coordinates at the beginning of the above lines will only work with the Simplistique skin. If you use this code on another skin, just replace the rest of the line after the last "," (Coma)
    My Fiero Build Thread
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by BavarianBuilt View Post
    Easy fix for this,
    right click the taskbar in the solid blue portion. click on properties. Then uncheck where it says "Keep the taskbar on top of other windows".
    Problem solved.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    or maybe get roadrunner to hide desktop/taskbar?
    Jul 2006
    Clifton, Virginia
    Quote Originally Posted by sama View Post
    Worked perfect. thank you guys so much.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    excellent
    Jul 2006
    JohnWPB - I was able to get iGuidance to embed using the strings you gave with one hiccup. When I embed iGuidance directly, I can use the Simplistque skins to send commands (like Mute). When I embed iGuidance using iGLaunch using the string you provided, the skin buttons don't work. If I use the following line in menu.skin:
    B06,400,217,380,84,"LOAD;IGUIDANCE.skin;iGLaunch;C :\Program Files\iNav\iGuidance\iGLaunch.exe;!TForm1,!iGLaunch",""
    the skin commands work sporadically. My question is do, you know how to both embed iGuidance (so the status and menu bars are hidden) and pass the skin commands at the same time? Thanks in advance.
  1. RR and Iguidance v3
    By kjones2k1 in forum Road Runner
    Last Post: 12-17-2009, 05:35 PM
  2. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  3. Replies: 17
    Last Post: 09-04-2006, 01:33 PM
  4. iGuidance GPS Issue in RR
    By moeman_49 in forum GPS
    Last Post: 06-04-2006, 04:17 PM
  5. iguidance in RR
    By sergatiuk in forum Road Runner
    Last Post: 03-06-2006, 06:00 PM
