Results 1 to 6 of 6
Thread: Cinfiguring windows to fit my Xenarc screen
    Aug 2006
    Hello, I did a few searches and didn't find an answer. If I set my display properties to 800X600 then the bottom of the screen is off the monitor. 1024x768 will fit the monitor. The road runner skin, however, fits my monitor perfectly at 800x480 or 800x600. Currently I have both the display and the skin set at 1024x768 and because of this I am not seeing all that I should in the skin. How can I fix this?
    Aug 2006
    Sorry, I posted in the wrong section
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    How do I fix a Skin that DOESN'T FIT or is NOT BIG ENOUGH ...
    I don't understand exactly what you mean by "fits the monitor", as far as I know any supported resolution should be automatically adjusted to fit your monitor. If you have covered part of your monitor's screen that's a different story.. anyway, read the FAQ above, there are also values you can use to position the skin on a different offset from the top left corner of the monitor, so just play with the numbers.. just don't change the originalxxxx= values.
    Ride Runner RR's Myspace
    Aug 2006
    My problem is that the windows desktop only fits the moniter when set to 1024X768. This being the case, adjusting the skin to 800x600 results in it being in the upper left of the monitor. Not understanding why my desktop does not fit the monitor when set to 800x600.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Did you read the FAQ ? did you try re-sizing the skin on general.ini ? did you try switching the resolution to run RR (option in RR Config) ? This is all in the FAQ.
    Aug 2006
    I did do all the above before posting my initial question.
  1. Replies: 3
    Last Post: 05-19-2006, 05:10 PM
  2. case and screen need to fit/.///
    By bginamercedes in forum LCD/Display
    Last Post: 08-24-2005, 12:30 AM
  3. Xenarc Touch screen issue with SONY T-140 Laptop
    By riuster in forum LCD/Display
    Last Post: 07-22-2005, 11:52 AM
  4. Xenarc Swivel Screen Mounted to Dash
    By pastypyro in forum Fabrication
    Last Post: 04-23-2005, 06:56 PM
  5. FS 7" Touchscreen Like Xenarc
    By sebcorazon in forum Classified Archive
    Last Post: 04-06-2005, 02:57 AM
