Results 1 to 3 of 3
Thread: Shutdown problem
    Aug 2006
    Shutdown problem
    Hi all, I'm french so sorry for my english ^^
    I have set RoadRunner as the shell as it's explained here: but when I exit RR (exit button is configured to Power Off) it's try to reload automatically rr.exe and I got 2 errors: "The application could not be initialized because the workstation is to be stopped" followed by "Can't access registry information..." and the computer is shuting down.
    I have tried to set AutoRestartShell to 0 in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon but the problem still.
    I have tried too to change Shell to C:\WINDOWS\system32\calc.exe and when i close the Calc its relaunch it.
    So anyone can help me to resolve these bugs please ?
    Aug 2006
    Hi !!! I've resolved the problem !!
    For all who are using Minlogon and a frontend as Shell I've found a solution to don't have these error messages while shutting down and reduce the duration of it.
    I have made a small program in C++ wich load the frontend and then sleep during infinite time.
    Here the source code for people who want it :
    #include <windows.h>
    int APIENTRY WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine, int nCmdShow)
    ShellExecute(NULL, "open", "C:\\Program Files\\RoadRunner\\rr.exe", NULL, NULL, SW_SHOWNORMAL);
    return 0;
    My program is named "shell.exe" and is located in C:\WINDOWS
    So in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    Shell = "shell.exe" instead "C:\Program Files\RoadRunner\rr.exe"
    Maybe it's a "barbarian" method but it's works and that's essential
    In attachement there is the file. You MUST have your rr.exe in C:\Program Files\RoadRunner else it will not load RR
    ENJOY !! and one more time: sorry for my english ^^
    Attached Files Attached Files
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    If you have VB6, you can step though the unload code and see what it's doing. It's probably some setting.
  1. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 06:09 PM
  2. Problem with shutdown controller
    By bobs987 in forum Power Supplies
    Last Post: 03-01-2005, 03:13 PM
  3. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  4. Arise MPD-810H shutdown problem fixed
    By jpainter99 in forum Power Supplies
    Last Post: 07-26-2003, 08:03 PM
