Results 1 to 10 of 12
Thread: Embedded Visualizations in RR
    May 2004
    When I run RR, winamp starts and the visualization window appears outside of RR. How do I get it to embed in the skin?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    First, make sure in the RRConfiguration program, you have defined the name of the visulization you are using. I reccomend using Milk-Drop to start with, as it is tried and true. If you get that one working, you can move on to something else. As your visulization is starting, it sounds like you have not set the name of the visulization correctly in the RRconfig.
    In winamp, (While winamp is in focus press COntrol K) and set the configuration for Milk-Drop and make sure that "Integrate with Winamp" is unchecked. This will do away with the visulizations title bar and borders.
    Next, you have to have a skin with a defined "Application area" that the visu will show up in.
    There are quite a few other things to check as well, but this should get you started.
    If you need some examples, download a couple different skins, and see how they are incorporating the visulizations.
    My Fiero Build Thread
    May 2004
    Ok, I see what I had wrong. The RRConfig had Milkdrop set as default but Winamp ran AVS as default. Thanks!
    Low Bitrate TxAxZxZ's Avatar
    Dec 2005
    FWB, FL (but currently in Belgium until 2016)
    what if you downloaded a different visualization than avs or milkdrop? I downloaded MojoMaster, which is a very nice vis of a 3d dancer dancing on an interactive stage. Both the lights and the dancer react to the music. I checked "other" in rrconfig. and typed in different names to try to get it to work. I tried the folder name (not the complete directory...just the folder name within winamp plug-ins). I also tried the .dll filename (again, not the complete directory, just the file name within winamp. ex. vis_MojoMaster.dll). What exactly do I need to type in the "other" box?
    This is what I am running:
    RR - Oct 8
    LSX Void - 1.6 (so far thee best skin I've seen!!)
    winamp 5.3 - (I know, I know) I'm not supposed to use it...but I think it's the only way to use this vis. I haven't
    tried it with the old version...that could be my problem right there
    BTW - JohnWPB...nice RX-7. My goal is to own a 3rd gen with a carpc. I'm interested to see how your did yours. Any pics?
    JeepTablet Project
    - Design <<<100%>>>
    - Construction <<<70%>>>
    View My Worklog
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Rx-7?
    Quote Originally Posted by TxAxZxZ View Post
    Heheh Actually it's a 98' Mitsubishi Eclipse. I'm lucky, as the dash has a Double Din for install. I put the head unit in the lower half, and a motorized touch screen in the top half.
    Dec 2005
    don't I feel stupid about now. Your avatar looks just like a 93-95 rx-7
    JeepTablet Project
    - Design <<<100%>>>
    View My Worklog
    Aug 2005
    Athens,Greece
    Did you manage to embed the mojo plugin afterall? Nice plugin, better than the avs ;-) but doesn't seem to work ....
    Nov 2005
    FL
    CLICK ME FOR BMW CARPUTERS
    95 Avus M3
    Mods: ;-)
    Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    RR - Oct 8
    Just incase you didn't get it working......
    "Mojo Master" is the window title, but with no config available you will get the frame.
    But what the hell.....it's a really nice vis
    My specs Winamp V2.95 / BMV2
    Wizz
    EDIT: PS; Give it time to load............................
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 07:54 AM
  2. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 11:52 AM
  3. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
