Results 1 to 4 of 4
Thread: Transitions
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Transitions
    Is there a way to use transitions for individual screens, or is this an all or nothing thing ?
    The reason I ask is because, as others with an Epia MII 10K M/Board will know, with transitions on, video's are very laggy.
    Or would it make any difference anyway to video performance if individual transitions were turned off ?
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Set transition=11 on RR.INI (or any effect you wish to be the default for all screens without custom defined effects) then add /EFFECT=X on each .skin that you wish to exit with a transition. Please Remember that there's one transition from ONE screen to ANOTHER (ONE transition between TWO screens), so the effect used is based on the effect set on the screen FROM which you're leaving.
    Ride Runner RR's Myspace
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by guino View Post
    Thanks Guino.
    I have found that with the use of your "video hide fix" beta and selected /EFFECT commands in the skin files, it is possible on carpc's with less powerful CPU's such as my Epia M10K, to have some transitions available, and still have a smooth video playback.
    The obvious screens to avoid trasitions on are video player, video browser, dvd player, and the screen where you select the video player. ( in my case the menu screen in BMV2)
    So...a compromise..but still some transitions
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can also use /EFFECT=-1 or /EFFECT=11 to disable effect FROM specific screens.
  1. RR 7-8-06.. Pic Viewer & more
    By guino in forum Road Runner
    Last Post: 09-11-2006, 01:35 PM
  2. Cameleon Skin [Concept]
    By JohnWPB in forum RR Skins
    Last Post: 08-24-2006, 09:53 AM
  3. Screen Transitions, Pic Viewer & Album Art effects
    By DiNASTY in forum Road Runner
    Last Post: 07-18-2006, 12:30 AM
