Page 10 of 27 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 262
Thread: RR 9-5-06 .. Native (iG) Gas Update ..
  1. #91
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by Evolution VIII View Post
    One more question
    Do you have GPS connected? what is your GPS coordinates(Lon. and Lat.)
    No GPS Receiver connected.
    Here is my html file.
    Attached Files Attached Files
  2. #92
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by MGD View Post
    Check post #90
  3. #93
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    WORKING NOW
  4. #94
    Aug 2005
    San Francisco
    Quote Originally Posted by liquid_smoke View Post
    I assume everyone is seeing this since the beta, but only seen it mentioned by me and you.
    I also see 2 blinks as mentioned using iGNative=true and transistions on.
  5. #95
    Dec 2005
    Miami-Florida-USA
    WORKING NOW
    Thank you guys for helping me find all potential problems with this thing.
    thanatos106, what about you? Have you tried?
  6. #96
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Cool, is working now... thanks.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  7. #97
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by kolemieux View Post
    LS -
    workin thru it and was using some of your code to help me understand some screen transitions to minimize this... ??? Should LASTSCR be working? I can't get any action out of that command and it seems (odd) to me. I don't want to use an EXIT because that seems to be closing IG on me.
    Can you test that command solo and see if it functions for you?
    Thanks to you and Matrix I know what to expect so at least am on par - THANKS!!!!
    "LASTSCR" works fine for me. If you dont want to use EXIT use ESC or MAIN.
    EXIT shouldnt close IG, only CLOSE should do that.
    Since you mentioned the LASTSCR command, i quickly tried this going to the audio player then to the gps, use LASTSCR to go back to audio and again to go back to GPS and the transition to and from is smooth as silk. Unfortunately this isnt a good way of doing it at all.
    beer replenishment fund
    mp3car live search
  8. #98
    Jun 2006
    LS _ gasprice... and LSX
    LS -
    Here is a very funky one.... I've been using gaspricefinder flawless - customized a skin, all is good - BUT - for some funky reason if I try to launch it from LSX (not void) --- even a fresh install with a pretty clean exectbl file - it hangs...... Makes ZERO sense. It did this with the beta and with the current RR.
    If you have a copy of LSX laying around could u try this and see what happens. It honestly makes no sense to me?
    also, turning off the transitions you can see more of what is actually happening.
    When it first loads, the first blink resizes the window to remove the file menu, the second blink removes the status bar on bottom.
    Entering the gps screen after load, you can still see the window nudge (wiggle) around a bit and reposition.
    Maybe this should be done to the window before it grabs it to embed and once the position is set i dont see any reason to keep reseting it.
    I also notice, changeing ignative=FALSE does not turn off ignative.
  9. #99
    Aug 2003
    Chicago
    just bumping this post.
    just grabbed the webplugin update. Scroll fav list works good.
    White box is gone also.
    One thing im noticeing is when the browser is open, its constantly (like every 2 sec) grabing focus. I cant drag another open window across the screen cus the focus changes mid drag. Not really a issue in the car as im not draging windows, but i do see it being a problem if i try to download any files, the save dialog goes under RR making this impossible.
    Also, i tried running it standalone, and i noticed that none of those things happened, the homepage also worked then.
    When i run it from a button in RR it just gives me the blankpage instead of loading the first fav.
    Im using
    "WEB","PLUGIN;WebPlugin;WebPlugin.exe"
    in ExecTBL
    mp3car live search
  10. #100
    Dec 2005
    Miami-Florida-USA
    LS -
    Would you mind to try this one ? Let me know if it works.
  1. RR 10-07-05 ... Small Update ..
    By guino in forum Road Runner
    Last Post: 01-30-2008, 01:29 PM
  2. RR 09-30-05 .. Quick update..
    Last Post: 11-16-2005, 09:29 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. RR Update question
    By RiiS in forum Road Runner
    Last Post: 08-16-2005, 04:32 PM
  5. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
