Page 3 of 27 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 262
Thread: RR 9-5-06 .. Native (iG) Gas Update ..
  1. #21
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Well as expected, guino left out part of the change in RemoveBorder() function.
    Code as of latest release 9/5
    Code:
    Public Sub RemoveBorder(hwnd As Long, Optional Top As Integer = 1, Optional Left As Integer = 1, Optional Right As Integer = 1, Optional Bottom As Integer = 1)
    Should Be
    Code:
    Public Sub RemoveBorder(hwnd As Long, Optional Left As Integer = 1, Optional Top As Integer = 1, Optional Right As Integer = 1, Optional Bottom As Integer = 1)
    Original code below is inside RemoveBorder() function
    Code:
    hw = CreateRectRgn(Top, Left, (WRec.Right - WRec.Left) - Right, (WRec.Bottom - WRec.Top) - Bottom)
    Should be
    Code:
    hw = CreateRectRgn(Left, Top, (WRec.Right - WRec.Left) - Right, (WRec.Bottom - WRec.Top) - Bottom)
    If I keep the above original code, the line below will be like this
    If hwnd = iGhwnd Then Left = Left + 20 (That doesn't look right)
    Instead of
    If hwnd = iGhwnd Then Top = Top + 20 (This look better, and that is why I change it.)
    Okay, since guino didn't change the function definition (parameters name) and call to CreateRectRgn's parameter, that is why iG get chop off on the Left instead of Top.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #22
    Sep 2003
    Beach City, Socal
    Chuck, you don't have to change it. PM me your email addy so I can sent you the fix above.
    I hope that guino fix it in time before mass download (and complain).
  3. #23
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i have the same issue with ignative. But i'll go ahead and add it to my source
    Live mp3Car Facebook Chat
  4. #24
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Is it me or is there a Bug in it. I tryed the POSX and POSY commands but my popup screen still displays in the center. I have those commands in the popup screen I am calling. Any advice?
  5. #25
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    I too have the same prob with ig...i can wait for the fix.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  6. #26
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    I guess I'll try IG
  7. #27
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Small question for guino or anybody about the web plugin... what engine\program\browser\app is the web plugin using (IE, FF,NS...) or the funcion in RR config file still there to pick one from IE anf FF?
    Thanks.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  8. #28
    Mar 2004
    Fort Myers, Fl
    i edited after i found that out. I did get it fixed.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
  9. #29
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by MGD View Post
    The syntax is (in the .skin file):
    /POSX=XXX
    /POSY=XXX
    I have tested it though, if it doesn't work for you, post your .skin section & filename and tell me which skin you're using.
    @MatrixPC: I went over the messages and that txt you sent and don't remember messing with the removeborder, either I missed it or it wasn't there.. I'll apply the changes posted, thank you.
    Ride Runner RR's Myspace
  10. #30
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    works fo me
    try
    /POSX=4
    /POSY=110
    2001 S10 ZR2
    Chucks Skin - to old
  1. RR 10-07-05 ... Small Update ..
    By guino in forum Road Runner
    Last Post: 01-30-2008, 01:29 PM
  2. RR 09-30-05 .. Quick update..
    Last Post: 11-16-2005, 09:29 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. RR Update question
    By RiiS in forum Road Runner
    Last Post: 08-16-2005, 04:32 PM
  5. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
