Page 8 of 27 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 262
Thread: RR 9-5-06 .. Native (iG) Gas Update ..
  1. #71
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by liquid_smoke View Post
    if you have clipareas defined in your external_gps.skin this will happen with ignative. So you'll want to remove them.
    The whole purpose of ignative is to remove the need to have to use skinbedder or other tools to remove the filemenu/status bar/borders etc from IG. So skinbedder etc should be disabled when using ignative.
    It also makes IG a child window of RR, so when you focus the RR window (click RR buttons etc) the embeded window dosnt flash or blink.
    It also removes the need to have clipareas defined in the skin, used previously to stop the flashing of embeded windows, but with the downside of seeing your desktop when switching to and from a screen that has clipareas.
    Thanks for the explanation.
    Now I just have to figure out if the skin has clip areas Also, when I load IG with IGNATIVE=FALSE, it clips the file menu bar. Hmmmmmmm.
    Off to search and see what I got.
    Michael
  2. #72
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by MGD View Post
    I can try this a hundred times and it always freezess. I don't know why, I have done everything to the specs. Once the .html file is deleted it works fine, if I leave it in the RR folder and restart RR and I go to the Gas skin it locks up.
    It seems that only you two guys have this problem.
    Few questions to help me understand the problem:
    1. Are you using MapPoint or IG
    2. What ZipCode you are using in GasPriceFinder
    3. Is it freezes every time you are entering the skin or when you exiting the RR and entering the gaspricefinder skin after that?
    4. Please send me that html file to email address I have on my profile(may be something wrong with the file).
  3. #73
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Wiredwrx View Post
    Michael
    Clip Area skin code begin with letter "C" such as
    CNN,XXX,YYY,WWW,ZZZ
    The area of the rectangle is the same as Application Area "A".
    Just put a comment infront of the line like this
    /,CNN,XXX,YYY,WWW,ZZZ
    Doesn't matter you set iGNative = true or false, menu bar, status bar, ... they all trim.
    With TRUE: you don't need clip area. iG and RR acting as one, and you can't use iGMon. If you use Clip area, you will see and empty hole with the desktop. Basically, Clip area cut out embedded area.
    With FALSE: You NEED clip area to stop flash/blink. You see desktop while coming to and going out of GPS screen. Work with iGMon. Basically, work like before.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #74
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by Evolution VIII View Post
    1. I am using IG 3
    2. I used 90040 and 91040
    3. When I start RR without the html file and load the Gas_Pricefinger.skin and input a zip code it displays the info just fine. Now I exit RR, restart RR and load Gas_Pricefinder.skin.....lockup. Every time.
    4. Can't attatch file when using send e-mail to....
    Jun 2006
    LS -
    ? - as you and I disussed this with the IG native beta... I have an external GPS skin file plain as jane... no clip areas at all. In the beta when it loaded it would blink on and off - we had discussed this. Now I am actually even getting a double blink of the screen before it settles in.
    Can you tell me if you are clean on this - or still seeing that. I seem to recall on the beta it did this on load - but not on exit....?
    Please let me know how yours is looking but with a very plain external gps skin it blinks about 3-4 times before settled in.
    Thanks to all...
  6. #76
    Dec 2005
    Miami-Florida-USA
    1. I am using IG 3
    One more question
    Do you have GPS connected? what is your GPS coordinates(Lon. and Lat.)
  7. #77
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    CF Style Skin
    Here is my CF style skin, can be used with the freedom skin or others.
    Works great on my home machine. Screen shot taken with out GPS hooked up so distances dont display.
    Click on addressess or distances to display on mappoint.
    with out further addoo
    Attached Files Attached Files
    New Age Garmin - Skin for RR
  8. #78
    Dec 2005
    Miami-Florida-USA
    Cool. Thanks for the skin. What kind of font are you using "Local Gas Prices"?
  9. #79
    Aug 2006
    West Allis, WI
    ThunderStick are you lost?
    Wrong thread. This is not discussion about GPSGAS plugin!
    THis is not GPS Gas, this is your native Gas Price Finder.... sorry for any confusion
  10. #80
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by kolemieux View Post
    LS -
    Thanks to all...
    If you have no clip area, set iGNative=true in rr.ini.
    Couple flash you experience with could be the transistion effect. Try to turn it off (transistion=-1 in rr.ini) to see if you still have the same flash
  1. RR 10-07-05 ... Small Update ..
    By guino in forum Road Runner
    Last Post: 01-30-2008, 01:29 PM
  2. RR 09-30-05 .. Quick update..
    Last Post: 11-16-2005, 09:29 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. RR Update question
    By RiiS in forum Road Runner
    Last Post: 08-16-2005, 04:32 PM
  5. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
