Page 1 of 27 1234567891011 ... LastLast
Results 1 to 10 of 262
Thread: RR 9-5-06 .. Native (iG) Gas Update ..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 9-5-06 .. Native (iG) Gas Update ..
    In this version:
    -Added iG Native Support (Thanks MatrixPC)
    -Added GPS GAS Native Support (Thanks EvolutionVIII)
    -Added command to set the directory list path by command
    -Added Support for sendkeys to send ; , and "
    -Added Support for commands based on Indicator States
    -Added Mixer support for Flash Objects
    -Added support to custom sizing and positioning of screens
    -Added commands to dynamically add and remove non-gesture areas
    -Improved List support for Flash Objects
    -Improved MM integration to leave it open on skin switch
    -Improved SCANMODE to work independent of screen
    -Improved SCANMODE to auto shut-off on skin switch
    -Improved Shutdown Procedure to never mute the Master Audio
    -Improved "PRESET" with option to load audio lines without master
    -Fixed issue with Video Player not hiding when effects are off
    -Fixed issue with SoundCard option selection
    -Fixed issue with Temp Sensor resetting too frequently
    -Fixed issue with Disc Change commands not working with car2pc adapters
    -Fixed issue with Radio getting stuck if Dlink selected but no card present
    -Fixed issue with vol+/- for winamp use (Thanks Robby_BMW)
    -Fixed issue with extension plugin indicators returning always ON
    -Created Native Web Browser Plugin
    I also Built RR with Mappoint's 2004 component so it works with 2004 & 2006.
    Notes:
    -Latest changes for iGnative support require INI option to be effective
    -Gas Prices support requires Gas Prices Files available at www.rrdownloads.net
    -For SendKey, Use {SC}, {CM} and {QT} respectively to send ; , and "
    The new Web Browser Plugin: it is fully integrated with RR, but it is completely optional. The existing methods to load the web browsers embedded will still work. You can download the plugin at www.rrdownloads.net .
    The easier install method is to unzip the exe in RR's folder, the .skin over the brushed metal skin and add this to exectbl (or change the .skin button code):
    "WEB","PLUGIN;WebPlugin;WebPlugin.exe"
    -It is backwards compatible with the existing web browser skins, but it requires a few more objects to be defined in order for the favorites list to work. Hopefully, skinners will provide the updated .skin files -- it only requires a list to be added, but offers more functions that can be added.
    -It will automatically load the first page in the favorites as start-up.
    -Its OSK resembles the windows OSK, so it should never loose focus of selected items (If I might add, it took plenty of research time).
    -You can double click on the favorite in the list to open the page OR add a button to load the page.
    -You can edit webfavs.ini OR create a button to delete items from the favorites list.
    It CAN be used with other front-ends. For that you'll need to create a sub-folder "SKIN" wherever you unzip the EXE, then place the wbrowser.skin and osk.skin files in it along with desired JPGs to be used. Those can be copied from any RR skin that supports a web browser.
    I hope I'm not disappointing anybody if it seems a short update after 2 months, but I really didn't touch much on it while I was out of the country.
    On another note, I wish to thank you for the amazing support everyone has provided to this project.. the 9th is my Birthday and I already got the best present the community could give me, yes the transflective screen too, but more importantly the recognition for my work and role here at the community.
    Thank you all so much for the support,
    Guino.
    Ride Runner RR's Myspace
    Raw Wave lostreception's Avatar
    NY
    thanks guino for all your hard work happy birthday a little early and enjoy that screen you deserve it
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    Heee I am second !
    Guino Thank you very much for all what you do for us and RR
    BMW X5 Carputer Project
    Finished: 85%
    http://www.mp3car.com/vbulletin/show...lots-pics.html
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    To clearify: Is iGnative a GPS gas app or a plugin for iGuidance v3?
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by DJiK View Post
    iG Native Support (Thanks MatrixPC) and GPS GAS Native Support (Thanks EvolutionVIII)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As he so put it, two different/unrelated things, I was just making a play on words with the title.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    nice update, and after fighting with issues with carweb, im happy to see the webbrowser plugin Due to current monetary erosion i couldnt pitch in on the screen, but your efforts here are not un noticed. You are probably the biggest single source of kickassness on this site. Happy early birthday, mine was just a few days ago.
    beer replenishment fund
    mp3car live search
    Low Bitrate Cali's Avatar
    Apr 2006
    CA
    You da man! Thanks for all your efforts, oh and Happy Birthday!
    Aug 2003
    Chicago
    got the webplugin working, and having a few very small issues.
    autoload of first fav dosent seem to work, i just get a blank white page.
    also, is there a way to navigate the fav list, arrow keys dont seem to work.
    thanks
    mp3car live search
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I intend to improve a bit on it... I'll make it so UP/DOWN work (button codes).. so it can be skinned a little better. It's just that favorites used to be handled by the browser only and now it's all in RR (better for the user, perhaps worse for skinners). If you make a skin with whatever function you want, I 'll do my best to make it work.
  1. RR 10-07-05 ... Small Update ..
    By guino in forum Road Runner
    Last Post: 01-30-2008, 12:29 PM
  2. RR 09-30-05 .. Quick update..
    Last Post: 11-16-2005, 08:29 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. RR Update question
    By RiiS in forum Road Runner
    Last Post: 08-16-2005, 03:32 PM
  5. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
