Results 1 to 8 of 8
Thread: Music initially loud then normal
    May 2004
    How come when I start Music or change to the next mp3 track in RR the audio starts off really loud for an instance then drops back down to the volume level I have it at? I'm using Winamp 2.95.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sounds like you have some normalization plugin installed. There's no such feature built-in into RR.
    Ride Runner RR's Myspace
    May 2004
    I just installed the winamp295 package on rrdownloads.net and I'm using LSX Void skin. I didn't tinker with the winamp install.
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Quote Originally Posted by guino View Post
    There was nothing documented on it, but i noticed my audio amps did this.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    May 2004
    This doesn't happen for me in Mediaengine and I believe that is winamp-based also.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The deal is that other FEs based on winamp normally ship winamp preconfigured with it. I'd suggest you take a look at your winamp's plugin settings. or even, just play with it OUTSIDE RR to see if the same happens -- if it does, it's not RR, if it doesn't then I'd like you to make a debug log in RR.
    May 2004
    Ok, thanks. I'll check it out
    May 2004
    Ok so I think I figured it out. The initial loud volume was occurring in Winamp outside of RR so it isn't a RR problem. In the Input plugin menu, wave_out was one of the 2 plugins installed (by default I assume because I never installed it). In the options, Volume Control Enabled was checked. When I unchecked it, the volume was working fine and it worked fine in RR. Thanks for the tip about checking the plugins.
  1. Music Indexing
    By aforget in forum StreetDeck
    Last Post: 02-06-2007, 10:25 AM
  2. Music path, Playlist path, Winamp
    By tmar89 in forum Road Runner
    Last Post: 09-12-2006, 06:56 AM
  3. Loading music in Road Runner
    By salvi in forum Software & Software Development
    Last Post: 07-27-2006, 07:29 PM
  4. ALways starts out loud
    By ZoLtRiX in forum Centrafuse
    Last Post: 09-12-2005, 11:15 PM
  5. GPS / Music Volume Issues
    By shakes in forum MediaCar
    Last Post: 07-08-2004, 03:47 PM
