Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Question regarding MPC and RR
  1. #11
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Your not using MPC,in your config you have USE BUILT IN PLAYER,the built in player is not MPC.
    Untick that box and your sorted.
    And i still recommend you install the CCCP codec pack and use the MPC that comes with that.
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As I said: you're using the BUILT-IN player -- that is NOT MPC.. uncheck that Built-in player option and RR will use MPC (and not the built-in player). Once you do that, whatever you play outside in MPC, should play in RR too.
    Ride Runner RR's Myspace
  3. #13
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by guino View Post
    I am not using the built in player for my setup and I still have that problem
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's likely the player klite installed is not the same MPC application. I can't be sure though, I am sure as hell not installing it to see. All I ever recommend installing is: DivX, XviD, QuickTime Alternative and Real Alternative. That's all I have and I have never been unable to play any file I came across. It's when we install those "PACKS" that it starts screwing up the system.
  5. #15
    Jun 2003
    Memphis - TN
    well damn! I though the MPC was the standard built in player!! Thanks for the info! I was thing external would be something like windvd and powerdvd.
    Update: Works Perfectly. Hung once, but will try and see if it continues.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. Problems playing DVD with RR 03-08-05
    By Passe in forum RR Bug Tracker
    Last Post: 06-24-2006, 01:36 PM
  2. Problem with embedded video player (MPC)
    By Erwin in forum Road Runner
    Last Post: 01-04-2006, 01:33 PM
  3. How is RR passing command to MPC player?
    By civic5zigen in forum Road Runner
    Last Post: 11-23-2005, 03:26 PM
  4. mpc problems for video & dvd
    By kuo in forum Road Runner
    Last Post: 09-28-2005, 08:18 AM
  5. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
