Results 1 to 10 of 15
Thread: Question regarding MPC and RR
    Jun 2003
    Memphis - TN
    I notice there is an updated MPC. Cant I just overwrite the one in the RR folder?
    Also I have some encoded videos that play perfectly in MPC as a standalone player, but will not play in RR, I just get a blank screen, no audio or anything. Any suggestions?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Whatever plays in MPC outside RR should work inside RR. If that isn't the case, most likely you have some bad codec (in which case you'd get audio at least) or some weird issue.. Try reloading the file from the browser, or different codecs.
    You can most definitely try the newer MPC (should work), but I would advise to make a backup first.
    Ride Runner RR's Myspace
    Jun 2003
    Memphis - TN
    Deff not a codec issue. If I open the program manually, it opens the file just fine, plays perfectly. I even tried copying the mplayer.ini to mpc.ini.
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Add the file extension to the supported list in RR config.
    Blank doesn't always work for me.
    Jun 2003
    Memphis - TN
    Its just an AVI , thats whats so confusing.
    I think I will end up trying a different player that works better with VIA boards.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you double check you're using MPC as the video player ? I have never seen MPC play something outside RR and not play it inside RR (except when using bad versions of the ffdshow plugin which caused it to crash). But I have seen videos play in MPC and not play in the Built-In player (which you may be using). In which case, it would be something screwed up with the machine's codec features in windows -- I have never found a way to fix this and have always fixed this issue by reloaded windows (though, I've only seen this twice).
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    I have the same problem Guino. All my videos plays in MPC but when I run it in MPC i will not play. Even when I change the MPC path to the external one that I have when installing Klite codec pack. I dont know why but it does. Also some video is glitchy when playing in the built in player but when I use change the path of the MPC to the one install by Klite it run smooth. Still the issue with the video crashing the whole RR. Can't figure that out yet.
    Jun 2003
    Memphis - TN
    I am also using the Klite codec pack. I have even tried to change the location of the MPC and pointed to that one instead of the one in the RR directory. I dont have any crashes though, just wont play those videos. If I open other videos within RR , they play fine.
    I'll try and take some screenshots. Im having my wife turn on my car PC and I will remote into it.
    Nov 2005
    Midlands
    Install the CCCP Codec pack and try the 1 that comes with it,it works flawlessly for me.
    Jun 2003
    Memphis - TN
    I have attached screenshots of my setup.
    Since you cant see the movie playing I took a snapshot of it playing in the MPC within the roadrunner folder.
    The screenshot of RR playing the movie shows exactly what I get.
    I have the exact same movie loaded within and outside RR.
    Im seriously baffled.
  1. Problems playing DVD with RR 03-08-05
    By Passe in forum RR Bug Tracker
    Last Post: 06-24-2006, 01:36 PM
  2. Problem with embedded video player (MPC)
    By Erwin in forum Road Runner
    Last Post: 01-04-2006, 01:33 PM
  3. How is RR passing command to MPC player?
    By civic5zigen in forum Road Runner
    Last Post: 11-23-2005, 03:26 PM
  4. mpc problems for video & dvd
    By kuo in forum Road Runner
    Last Post: 09-28-2005, 08:18 AM
  5. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
