Page 10 of 37 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #91
    Mar 2005
    Sweden/Vaxjo
    well I just tried the released version that has the pause function and it's sweet... Finally I can hear all the directions since it pauses the music... I skipped the auto-switch feature since I had some problems getting it to go back to the previous screen... but I think the audio directions is good enough most of the times...
    as said earlier, I hope this makes the next release of RR... most ppl are using IG as it seems and it's a damned nice addon for it...
    Swedish site for CarPC's
    http://www.bilpc.info
  2. #92
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Naesstrom View Post
    Are the maps for Europe up to date then ? (Guess you're in Sweden, Yes ?) I'm in the UK, and although IG is really popular in the USA, I'm still using MapMonkey because I have heard that IG has old maps in the EU edition.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  3. #93
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by MatrixPC View Post
    Alright guys, so far, I use it over the weekend and all work as expected. However, during development, I found a BIG BUG that I could NOT replicate (as I forgot exactly what I did). The problem is that you STUCK in GPS screen (the one that auto switch to), because RR keep execute "GPS" command. I can not go to any screen. I have to kill RoadRunner and re-start it.
    I try all posible combination I think I did, but I can't reproduce the bug. Basically I use RR's CLOSE command to close iG screen during auto switch to GPS (either by Voice or Guidance I forgot).
    Let me know if any of you run into this problem. Base on the code, I don't see anything that can cause a bug that BIG. aren't all programmers said that?
    Anyway, report all bugs so I can fix them before I send the code to guino by the end of the month for November offical release (if there is one) .
    Lastest download can be found on post 54. Thanks 65coupei6 for hosting the file. RoadRunner_auto-iG-10-20B.zip is the file name of latest release. RoadRunner_auto-iG-10-19B.zip is the one without pause/resume music.
    This is a great addition to RR. Good job guys.
  4. #94
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by wizz View Post
    Wizz
    well I do a lot of driving both for my work and in private but so far I havn't had any big problems with the maps... it's happened once and that was when they were rebuilding the road so they had made a new one while doing that...
    it's real bad that they wont do any IG v3 for europe, I can't see why really, but thats life...
    I stopped using MM long time ago since it crashed a couple of times to much... if CDr's Freedrive 2 comes out I might get the Destinator 6 discs just cuz of that...
    It's nice with a navigation software that works in-line with RR...
  5. #95
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    who would like to have dynamically change lastscreenswitchtime value during run time via SETVAR command?
    To me it's just good as is. But if you want to change it base on whatever reason, SETVAR can do that (well, I need to modified couple line of code).
    Let me know.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #96
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    That would be neat but not necessary
    But if you could add a little more time to the lastscreenswitchtime=[0-20] that would be good
    2001 S10 ZR2
    Chucks Skin - to old
  7. #97
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Chuck View Post
    At first I thought 10 second would be good, but after a drive over the weekend, it isn't long enought. I am going for a little more flexible [5-30]. Anything less than 5 mean no switch back.
    Run time change need to modified existing skin to take advantage of it. I'll do it depend on feed back from you guys.
  8. #98
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    This add-on is not for me as I find pausing music and auto-switching screens very annoying. However, I would love to have a label that displays the next turn like with iGMon. I would also love the GAS plugin to auto-route in iG when you click a station. I would also totally love integration between iG and RREarth (enter a destination in either and it is auto-entered into the other).
    ...just in case you got a ton of free time now that this is done Matrix j/k
  9. #99
    Sep 2006
    Sabattus, ME
    so i just tested this out, and it works great with the expcetion of a few things.
    1). The ding is really really annoying, it pauses the music for the ding then unpauses then it pauses again for the actual voice instructions.
    2). When having visualizer on and it switches to gps when it goes back the visualizer it is "behind" so it needs to be alt+tab'ed to see it again.
    and this kicks *** sooo hard!
  10. #100
    Nov 2004
    L.A.
    You should be able to avoid #2 by adding a Clip-Reigon to your skin (in the same size/pos as the Vis).
  1. Replies: 4
    Last Post: 01-26-2006, 02:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 02:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 02:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 11:10 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
