beer replenishment fund
mp3car live search
what examples?
im done with the code, im just testing it out now. I think i may have found a bug in igautosw though. Just making sure its not my code.
mp3car live search
Umm - meaning Smoke or LSX update so we can examine and use with some of the stuff you managed to tweak around. I have seen many posts on "work arounds" --- like that volume one you mentioned which I agree was a very good one....
Just for us trying to digest all of this thread with a KILLER FEATURE I needed bad. I am just a bit behind on this one so usually learn best from a SKIN or a FAQ....
Just let us know - I did not know if you were working on an update or new skin release. I have been working on some side-stuff Guino whipped up I planned to release this weekend that people would think is kewl...
Oh you mean included in lsxvoid,
it depends. Ill likely have it as an option (most likely). It'll prob be turned off by default and let people choose how they want to handle igpause and igresume.
Im having some issues with it right now, my code is clean.
I think there is something going on with the wav volume, i think igautosw is changeing the wav vol to match the IG voice volume, half way through my trip it hangs up and forces my wav vol to something other than what it was set.
Still need some more testing though.
I may post the code so others can test it and report any issues they may have or not have. May be just me.
mp3car live search
You can try something like this. (I am not 100% sure if it works, but you get an idea)
Winamp volume range is 0-255
set pauseonvoice=true in RR.ini
then in ExecTBL.ini add these 2.
"IGPAUSE","SETVOL;WINAMP;100"
"IGRESUME","SETVOL;WINAMP;200"
That will lower winamp to 100 then resume to 200 instead of PAUSE/RESUME
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
im doing something similar to that, except it remembers whatever your original winamp volume was before it changes it. Im also using variables so i can use the same features on a button toggle or for other things.
Im monitoring my wav volume thats originaly set to 100% and ig voice volume is set to 20%, after a few successfull voice prompts something changes my wav vol to match the ig voice volume
mp3car live search
Well if anyone wants to test it out,
add this to your ExecTBL.ini
Code:"IGPAUSE","DUCK" "IGRESUME","DUCK" "SETVAR;ATTENTION;0" /winamp 120 is the volume that winamp will be lowered to, values from 0-255 are valid pick one that makes you happy "ATTON","!PRESET;IG3||SETVOL;WINAMP;120||SETVAR;ATTENTION;1" "ATTOFF","PRESET;IG3||SETVAR;ATTENTION;0" /this can command "DUCK" can be used as the code for any button to toggle the commands "DUCK","BYVAR;ATTENTION;ATTON<<ATTOFF"
optional label you can add to know the status
label code:
Code:"BYVAR;ATTENTION;=ATT OFF<<=ATT ON"
if you test this out, let me know if you have any issues.
mp3car live search
This didn't work for me. I added the code to the ini and ran iG in demo mode but it didn't lower the volume. I am sure I am missing something blatantly easy but I am not seeing it. Any suggestions?
