Page 16 of 37 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 365
Thread: Auto switch to Guidance screen for iG?
  1. #151
    Jun 2006
    LS - I promise to ask minimal stupid questions, but could you possibly give a quick overview of what the following syntax accomplishes.... I am grabbing and going to test....
    I think what you suggested is what I am after - I'd like the SWITCH and rather than perhaps a pause, a VOLUME minimize, then VOLUME raise on the SWITCHBACK....
    I think this is AWESOME...
    Quote Originally Posted by liquid_smoke View Post
    Well if anyone wants to test it out,
    add this to your ExecTBL.ini
    Code:
    "IGPAUSE","DUCK"
    "IGRESUME","DUCK"
    "SETVAR;ATTENTION;0"
    /winamp 120 is the volume that winamp will be lowered to, values from 0-255 are valid pick one that makes you happy
    "ATTON","!PRESET;IG3||SETVOL;WINAMP;120||SETVAR;ATTENTION;1"
    "ATTOFF","PRESET;IG3||SETVAR;ATTENTION;0"
    /this can command "DUCK" can be used as the code for any button to toggle the commands
    "DUCK","BYVAR;ATTENTION;ATTON<<ATTOFF"
    optional label you can add to know the status
    label code:
    Code:
    "BYVAR;ATTENTION;=ATT OFF<<=ATT ON"
    if you test this out, let me know if you have any issues.
  2. #152
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by jeffreyd_tx View Post
    This didn't work for me. I added the code to the ini and ran iG in demo mode but it didn't lower the volume. I am sure I am missing something blatantly easy but I am not seeing it. Any suggestions?
    check to see if you dont already have IGPAUSE and IGRESUME set elsewhere in the same file.
    Does the screen switching still work?
    Also note, you will not visually see the volume change in RR, by looking at volume sliders or label cuz it changes the winamp volume. To be sure its not changing the winamp vol, Run RRConfig.exe and uncheck "Hide Winamp", then when IG speaks watch to see if the volume in winamp changes.
    I does work, but i do think there is some issues with something, not sure quite yet. When i run ig in demo mode it will work flawless for about 80% of the route then igautosw just stops working completely.
    Im going to do some more test to figure it out.
    beer replenishment fund
    mp3car live search
  3. #153
    Aug 2003
    Chicago
    Quote Originally Posted by kolemieux View Post
    it does exactly what you think it does. One person says its not working for them, so if you could test it on your end that would be cool.
    mp3car live search
  4. #154
    Newbie technostar's Avatar
    Sep 2006
    I tested this plugin tonight with lsxvoid skin when I drove to work, I did exactly what the text file told me except adding in the commands on the exectbl.ini, and it worked fine. It pause the player and switch the screen to ig and switch back to previous screen when its done. What I noticed is that theres a gps speedo on the skin that it is acting weird when it's switching back to previous screen...
    so far i think this plugin is great... thanks
  5. #155
    Aug 2003
    Chicago
    what does the gps speed do when you are switching?
    mp3car live search
  6. #156
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Hey matrix
    small and easy request that could potentially add a new level of integration. Can you have your plugin set an "Guidance" indicator when guidance mode is detected. I have a OCR script that can read the turn distance from iG and set it as an rr variable Then from there.... modify the variable using a formula that calculates from GPSSPEED, GPSLAT and GPSLON. With this we can have the turn distance displayed on any other rr screen. i could POTIENTALLY also be able to read the turn arrow for display as well.
    But in order to do this i'd need to know when ig is in guidance mode. SO i'd need your program to setind;guidance;ON when in guidance mode and setind;guidance;OFF when its not.
    Live mp3Car Facebook Chat
  7. #157
    Sep 2006
    liquid_smoke
    the gps speedo will put some 4 or 5 digit numbers, sometimes freezes up to the last number read, then acts normal again. It's doing this about 30 to 45 seconds after the switched.
  8. #158
    Aug 2003
    Chicago
    thats odd.
    does it do this on all screens that have the speedo?
    This should prob happen using any skin also, the speedo is just a standard label. But I noticed when i was doing a little house cleaning that there were multiple gps speedo's on a single screen.
    mp3car live search
  9. #159
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Sonicxtacy02 View Post
    Hey matrix
    I am not sure how to do it yet, but let see.
    You want an indicator or a label?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  10. #160
    Woodbridge, VA
    Blog Entries
    55
    an indicator. From outside rr this would be the code
    SETIND;CUSTOMguidance;ON - turns it on
    SETIND,CUSTOMguidance;OFF - turns it off
    i'll have to peek at the source to figure out how to add it internally
  1. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Auto off switch
    By Ill1 in forum General Hardware Discussion
    Last Post: 01-17-2005, 03:50 PM
  4. auto start/shutdown with tower switch
    By HybridFox in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:10 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
